Old May 17th, 2019, 19:53   #1
Scottgenstein
Default 2015 Sportwagen TDI recurrent P00BD code
My TDI keeps throwing up excessive mass air flow (P00BD) OBDII codes. Car runs perfectly and has only 35K miles as of today, but has been giving me that code intermittently for probably two years! I discovered 6 months ago that the car was manufactured minus one screw right by the mass airflow sensor and corrected the problem. The CEL disappeared after some time and stayed off for maybe 1500-plus miles but has returned again along with the CEL. The code apparently is a so-called "permanent" code that will stay off only if the OBDII drive cycle is deployed to reset the readiness monitors. The drive cycle one dealer was kind enough to provide me reads in part "DRIVE: Vehicle for 30- 40 min at a constant speed of 50 -70 mph in high gear for 2 min with no coasting." How can I drive for 30 - 40 minutes for 2 minutes? If anyone can get an answer to that question I would be very appreciative since obviously that's some sort of misprint. Anyone else have this problem?
Scottgenstein is offline   Reply With Quote
Old May 17th, 2019, 19:57   #2
ProfBrown
Fuel Economy: In the sig
Wonder if they meant miles? As in drive 30-40 miles at that speed for that time?
2015 GSW TDI SE DSG
DON'T TRACK THIS ANYMORE
ProfBrown is offline   Reply With Quote
Old May 18th, 2019, 11:24   #3
Scottgenstein
Thanks, ProfBrown, but to drive 30-40 miles at that speed cannot be done in 2 minutes--it would take 30 to 40 minutes!
Old May 18th, 2019, 11:49   #4
Scottgenstein
Also, has anyone else had recurrent P00BD codes with no apparent real problem with engine functioning?
Old May 18th, 2019, 14:31   #5
Lightflyer1
Lightflyer1's Avatar
I would just try the procedure ignoring the 2 minute part. 30 to 40 minutes at 50 to 70 mph, no coasting. You are trying to reset the monitors and they don't usually reset in a short period of time. What can it hurt other than some wasted time and fuel?
Old May 18th, 2019, 14:52   #6
Scottgenstein
Thanks Lightflyer1--been figuring I'll do that late at night, and since I need a continuous 1 hour trip I'll have to also take a 1 hr return trip, thus running 2 cycles. What a pain!
Old May 18th, 2019, 16:15   #7
Scottgenstein
Well, I won't even have a chance to try the drive cycle. The damned thing brings up the code within minutes of driving and within a bit more the CEL illuminates, so I have to dig further. I'm now looking for what the proper mass air flow should be at idle--my car idles right around 770 rpm with MAFlow at about .900 lbs. I've no idea what the MAF should be and am searching for info. Naturally, I'll clean my MAF sensor before proceding but I really don't think that's the problem given lack of symptoms but for CEL and DTC P00BD. Thanks all for your input. I don't have an honest mechanic near me that I know of and the dealer I've gone to just tries to defraud me by saying, for ex., that I need a new air filter when I just installed one a few weeks prior, etc. etc. etc.
Old May 19th, 2019, 05:30   #8
thundershorts
I wouldn't touch the MAF as its a warranty item and usually have paint on the anti tamper screws. You could be screwed for hundreds if it turns out to be the culprit and VW sees its been tampered with. Did you install an oem air filter or something else?
"You can't argue with a fool..."
thundershorts is offline   Reply With Quote
Old May 20th, 2019, 12:28   #9
Scottgenstein
Thanks, thundershorts, for the warning re. warranty. My memory was off about the air filter--I had checked to make sure it was clean but it didn't need replacement so it's the original that came with the new car.
code P00BD Funguy VW Passat Family (NMS and B7) TDIs (2012+) 36 May 18th, 2019 12:03
Used 2015 tdi sportwagen pharw Dieselgate - VW Group Emission Scandal 10 June 8th, 2018 07:32
2015 TDI Sportwagen your 2 cents please Embassy_Marine VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 16 April 20th, 2017 10:54
TDI 2015 S sportwagen Manual ssalaun VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 5 September 15th, 2015 08:40
2015 TDI Sportwagen deming VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 1 September 3rd, 2014 18:56
Page generated in 0.14379 seconds with 10 queries
[Output: 88.88 Kb. compressed to 75.96 Kb. by saving 12.91 Kb. (14.53%)]
