Go Back   TDIClub Forums > Meetings/ GTG/ Regional Discussions > Atlantic Canada
Atlantic Canada Atlantic Canada Section. This section is for people in Atlantic Canada to discuss items more local to them.
Old May 13th, 2019, 05:51   #1
johnnycanuck
Default replacing Strut mounts on 2004 Jetta
The bearings on my strut mounts are worn, I had new struts put on Dec 2018 but the mechanic for some reason did not replace the mounts/bearings. Is there a way to replace the mounts without compressing the springs?
johnnycanuck is offline   Reply With Quote
Old May 13th, 2019, 09:46   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Nope.
oilhammer
www.cardocautomotive.com
Old May 29th, 2019, 15:21   #3
johnnycanuck
Default Replacing Strut Mounts.
Do I have to remove the Strut completely to replace the mounts and bearing? can I just compress the springs? Is there a trick to it?
DIY How To Easily Upgrade MK4 Front Strut Mounts Cupra R Mounts TDI_G VW MKIV-A4 TDIs (VE and PD) 32 November 25th, 2018 05:24
Strut Mounts (A4 Jetta) stowebay VW MKIV-A4 TDIs (VE and PD) 4 July 7th, 2017 07:17
replacing motor mounts on 09 Jetta MaroonB4 VW MKV-A5 Golf/Jettas 5 October 9th, 2015 13:56
Replacing RS strut. Removing PS strut. WillR VW MKIV-A4 TDIs (VE and PD) 11 January 31st, 2012 07:49
98 Jetta Strut mounts hendomatic TDI 101 1 October 8th, 2007 17:50
Page generated in 0.12412 seconds with 10 queries
[Output: 57.19 Kb. compressed to 51.92 Kb. by saving 5.27 Kb. (9.22%)]
