Old March 13th, 2003, 21:34   #1
JettaTDI777
TDI(s): Sold It
Default Security code for factory Jetta radio
Does anyone have security codes for the factory radio? Or is it based on the serial number of the radio? I am planning on selling my factory radio but I want to make sure the buyer can install it. Any input would be appreciated.
JettaTDI777 is offline   Reply With Quote
Old March 13th, 2003, 21:50   #2
weasel
Deactivated Member Account
TDI(s): None.
The security code should be in your owners manual. If that's not available, you will have to bring the serial number to the dealer to get the code.
weasel is offline   Reply With Quote
Old March 13th, 2003, 22:02   #3
JettaTDI777
TDI(s): Sold It
Well thats a bite in the rearend.....under the serial number and security code it was blank in the manual.
Old March 14th, 2003, 05:51   #4
Tom_S
Fuel Economy: 45/43/38
It's not a big deal. I recently purchased and installed a used replacement for my Premium IV radio. It came without a code. Just take the radio (or at least the serial number) to the service department at you dealer. They may also want the V.I.N. from your car. They input the radio serial number into the computer and get back the code that you need. It took about 3 minutes to get mine.
Tom
Tom_S is offline   Reply With Quote
Old March 14th, 2003, 05:52   #5
Navig8ur
I had to get my '03 radio reset and the salesman looked in the spare tire compartment and then wrote down a code, he then went to the radio and reset the code.....I have never looked myself in the compartment but I suggest you remove the bottom of your trunk and have a look around.
Navig8ur is offline   Reply With Quote
Old March 14th, 2003, 07:30   #6
TSmith
I just looked in my trunk and found the label that contains the radio code. It is on a small white piece of paper stuck to the painted area to the left of the spare tire. It has a long number/letter sequence starting with VW... and below that is the 4 digit radio code. Hope this helps.
TSmith is offline   Reply With Quote
Old March 14th, 2003, 09:12   #7
JettaTDI777
TDI(s): Sold It
Ya know what as a matter a fact that's what I found too when I went into the trunk. Is the security code 4 digits?
Old March 14th, 2003, 10:23   #8
Navig8ur
Yes.....you owners manual will have the instructions on how to enter the code.
Page generated in 0.14261 seconds with 9 queries
[Output: 76.72 Kb. compressed to 65.57 Kb. by saving 11.15 Kb. (14.53%)]
