Orders TDI Club Cards TDI Fest 2010 Gone, but not forgotten VAG-Com List Unit Conversions TDIClub Chat Thank You
User Name
Password
VW MKIV-A4 TDIs (VE and PD) This is a general discussion about A4/MkIV Jetta/Golf (99.5-2004) & New Beetle. Both VE and PD engines are covered here.
Thread Tools Search this Thread
Old October 29th, 2007, 23:19   #46
bioduse
bioduse's Avatar
Originally Posted by whitedog
Hopefully someone that actually knows something will wander in and help me out.
15: Tandem pump (fuel pump and vacuum pump together)
Does anyone have a part number (VW's name for this part?)
for #15? I have a leak . . . .
thanks
Abuse of authority comes as no surprise!
RC1+ - Sachs VR6 clutch - Ventectomy - Mufflerectomy
bioduse is offline   Reply With Quote
Old October 30th, 2007, 05:38   #47
tditom
aren't some vehicles covered by a recall for tandem pump leaks?
tditom is offline   Reply With Quote
Old October 30th, 2007, 07:33   #48
bioduse
bioduse's Avatar
So, they are called tandem pumps . . . .
you have a ETKA part number ?
yes, there are some vehicle covered bt tandem pump leaks . . . . .
Old October 30th, 2007, 09:16   #49
Trog thou Meatier
Trog thou Meatier's Avatar
Try http://www.vagcat.com. The part number for my vehicle appears to be 038145209E.
Check the fuel lines going to and from the tandem pump before you replace it. What looks like a leaky pump could just be bad lines.
'01 Bora Sport, 114K miles, AJM, 6-speed manual
Trog thou Meatier is offline   Reply With Quote
Old October 30th, 2007, 13:57   #50
PDJetta
PDJetta's Avatar
The coverage is roughly mid to late year 2004 and early 2005 BEW engine code. Other PD engine codes may be covered as well. Its by VIN number.
--Nate
Old October 31st, 2007, 11:01   #51
bioduse
bioduse's Avatar
038-145-209-N
is the part number for the
BEW PD "tandem/vacuum/fuel" pump
Old November 2nd, 2007, 06:10   #52
troymobley
Default oil filter which end goes up?
The tdi filter (2003 Jetta TDI) has a ledge up inside on one end but not the other, which end slides on the tube first? Thanks, first oil change. Thanks Troy
troymobley is offline   Reply With Quote
Old November 2nd, 2007, 07:52   #53
TornadoRed
TornadoRed's Avatar
What I think you mean is the plastic oil "dam", that holds some oil inside the filter after the engine is shut off. That "dam" needs to go on the bottom, otherwise all the oil would drain out. Without the dam, it would take another 1/2 second or so for oil to reach all the top end of the engine.
'03 Golf with 305k miles: Kerma Bosio PP520, Hammer 1849V, Passenger Performance 2.5" DP, Aligator tuning, VR6/G60 clutch/flywheel, Koni Reds, Houstons, Recaros, Akebonos, CAT, Old Navy CCV, DG Panzer skidplate, Hidden Hitch, Mobil 5w40
Foobert's TDI Hunt -- all Craigslist TDI ads nationwide
Old January 2nd, 2008, 11:48   #54
mogaf
Thumbs up seat alhambra tdi pd engine
Hi i'm new to this site and wondering if someone can help, i've got a seat alhambra tdi pd engine, the fault i've got is no vac to the turbo, ive checked the N75 valve and no vac from there aswell i've search all the vac pipes but no vac any where.
could you guys tell me where the vac actully starts from, so i can start from the bringing.
Or if someone has a Diagram of the vac pipes and valves.
Grateful if anyone can help
mogaf is offline   Reply With Quote
Old January 2nd, 2008, 11:50   #55
tditom
mogaf-
I believe your engine has a vacuum pump operated by the camshaft. On my ALH motor there is also a reservoir.
-tom
'01 Golf (MI gtg TB )
'97 Passat (my ditch diver )
'91 Jetta ECOdiesel (sold to biobill )
'98 NB (for my daughter )
Old January 3rd, 2008, 17:31   #56
mogaf
Hi Tom, Thanks i've found the vac pump, now i need to know is how all vac pipes are contacted and where the vac starts from or if someone has a DIAGRAM of the VAC pipes.
Old January 3rd, 2008, 19:56   #57
merkerguitars
Send a message via AIM to merkerguitars
Originally Posted by aprilone59
where is the engine code,99.5 jetta tdi
my timeing broke at idle should i expect valve damage?
thanks.
You definately have valve damage.
Your Twin Cities area TDI mechanic, can do all sorts of work with over 5 years of experience, just PM if you need service.
merkerguitars is offline   Reply With Quote
Old January 4th, 2008, 16:50   #58
aNUT
aNUT's Avatar
thanks.
You may want to start your own thread on this as this is getting off topic. I left a ratchet on the crank pulley bolt during a test start post TB job. It removed the crank pulley, resulting in broken TB symptoms. This was at idle. Damage was 5 bent valves - 2 intakes, 3 exhaust. 4 lifters were visibly destroyed, though I replaced them all. Cam and low end were fine.
aNUT is offline   Reply With Quote
Old March 9th, 2008, 09:50   #59
certifiedwreckedvwtdi
certifiedwreckedvwtdi's Avatar
Default air intake
Originally Posted by loggin
1. Air Intake, if I left this off would it lower fuel economy?
TotallyDementedIndividual
Certified (as in CPO) Wrecked 2005 GLS JETTA TDI (auto) Purchased from Hiley Volkswagen Arlington, TX. WHAT SOME GREAT FOLKS! NOT!!!!!!!
certifiedwreckedvwtdi is offline   Reply With Quote
Old March 14th, 2008, 15:25   #60
Default Help! Need Part Number.......
PD engine
I need the part number for the black plastic thing behind the drivers side headlight(has four screws), in front of battery. in the picture it is just right behind the box with 13 in it.
Search this Thread:
Advanced Search
vB code is On
Powered by vBulletin Version 3.5.1
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
© 1996 - 2010, All Rights Reserved
Message Boards and Forums Directory
Page generated in 0.61485 seconds with 11 queries
[Output: 96.62 Kb. compressed to 89.29 Kb. by saving 7.33 Kb. (7.59%)]
