Go Back   TDIClub Forums > Picture Gallery/Specs of Members' TDIs > Passat TDI Picture Gallery
Passat TDI Picture Gallery Do you have a Passat TDI? If so write a message here describing it and insert a picture if you have one. If you don't have one on the computer, email me and I'll give you my address and I'll scan it for you. If you need web space for it, email me as well. Please make a short yet descriptive title for your vehicle.
Old June 1st, 2018, 17:27   #1
goodmonkey
goodmonkey's Avatar
Default 2014 Passat TDI SEL - Another goodmonkey car
Bought this today. The picture is one I took at the dealership on my way out. There were still a few things service needed to take care of to be certified (I asked to make it a CPO car), so it is supposed to be detailed and delivered to me tomorrow. Bought from Keffer VW in Huntersville, NC, with 70k on the clock. Emissions mod was completed last June. I finally have my white VW.
2014 Passat TDI SEL (DSG) - 102k, 2011 Touareg Executive -149k
Previous TDI's: 1996 Passat TDI- totaled at 394k miles, 1998 Passat TDI - 175k miles, 2012 Passat TDI SE - 41k, 1996 Passat TDI Variant - 327k, 2014 Jetta SportWagon TDI 6MT - 29k, 2015 Passat TDI SEL - 18k, 2006 Jetta TDI 5MT - 261k
goodmonkey is offline   Reply With Quote
Old June 2nd, 2018, 11:08   #2
Ralftex
I just made a deal on a 2015 VW Passat SEL and it is at a VW dealer. Has 26k mikes But how much did they charge you extra to be certified. This car was supposed to be certified but because of the price. $16,300. They didnít want to do it and took certified off. Iíll upload a pic when I get it
Ralftex is offline   Reply With Quote
Old June 2nd, 2018, 12:09   #3
goodmonkey
goodmonkey's Avatar
Ralftex,
I sent you a PM about my CPO costs. Each market is a little different, but what you've stated so far from a VW dealership looks like a decent deal. I was going to go for a 2015 with 70k miles that was CPO, and it was just a couple hundred dollars more than that. It wasn't ready on my day off (going through emissions modifications) so I went to look at the 2014 and decided I liked it enough to pick up.
Car was delivered to my house today, and I've done my first mod and have my first maintenance action to do. The right DRL bulb burnt out since I bought it yesterday.
Old June 4th, 2018, 16:51   #4
goodmonkey
goodmonkey's Avatar
Default I've owned a few
Here is an update to a graphic I did in 2014. I don't know that I shared the original though. Some might recognize a few of them. The last 8 are all TDIs.
Old June 17th, 2018, 07:01   #5
goodmonkey
goodmonkey's Avatar
Default Its the small things
So far it has been small stuff done to the car. I changed the oil because I found out that the PO had allowed oil with a VW spec of 505.01 and not 507.00. Had somewhere less than 2k miles on that, so when the oil came in I did a topside change. I also changed out the DRL bulb, so now those work.
Looking at the lights I ordered some Night Breakers to go in the low beams, but then I found someone selling a used HID conversion kit from DeAutoLED, so once that comes in those will be in the lows instead. I may install the night breakers in the high beams or just save them until something burns out.
Another order of used stuff came in this week. In there the was a CargoMat for the trunk and Monster Mats along with some other things. Those were the two I was looking forward to the most, and they are in now. Gives the car a different look. This is a SEL, but also my daily driver.
Up next to ponder: To tune or not, look into the latest firmware for the RNS-510, rain/light sensor, and possible hard wire for the dash cam. It would be great to tackle that and the rain/light sensor at the same time. Oh, I also found out the drivers door puddle light is out, so I have to look into replacing that and how hard it would be to add them to the rear doors. A skid plate is also high on the priority list.
Because I do like ventilated seats, I tried a ventilated seat cushion. It did move a lot of air around, so in that respect I liked it. I did not though like the way it sat in the seat and I could just not get comfortable in the car with it. It also was hotter without the fans running than the regular seat, so that came out halfway through my commute and I'm just going to have to adjust my expectations for the seating. I'm not looking at a $1500+ upgrade on the seating yet, especially if I'm trying to work out in the budget doing a tune.
Old October 29th, 2018, 16:24   #6
goodmonkey
goodmonkey's Avatar
Tonight I updated the RNS-510 to SW-version 5382, which went quicker than I thought, under 25 minutes. I'm still seriously considering a RCD330G with Android Auto. A couple weeks ago the Passat was in at the dealer having the heater core replaced, so we took her car on a short vacation. We both used our phones with Google Maps and it helped a lot and was easier to enter addresses and get traffic updates than use her car's GPS.
UPDATE 11/4/18: I ordered a RCD330G and will try it out. I really wanted to go with the newest AVIN unit, but with no real reviews I passed. I may go that route eventually, depending on how the RCD330G works out.
Last edited by goodmonkey; November 4th, 2018 at 16:10. Reason: Update on RCD330G.
Old December 17th, 2018, 14:52   #7
goodmonkey
goodmonkey's Avatar
Default Next Upgrade Hopefully
I got in what I've eyed for some time, for my older Passat when I had it and the Jetta too. The hardest part for this I see being getting the sensors in place. I feel comfortable enough to do the wiring and coding. This should of course work with the RNS-510 or the RCD-330G for the visual aid, or OPS. In absence of either of these I'll still get the audio feedback.
It could be a while before I get it in though. I still not tried out the RCD-330G.
Old February 24th, 2019, 20:10   #8
JELLOWSUBMARINE
JELLOWSUBMARINE's Avatar
Originally Posted by goodmonkey View Post
Tonight I updated the RNS-510 .
Interested in selling RNS 510?
JELLOWSUBMARINE is offline   Reply With Quote
Old March 9th, 2019, 06:20   #9
goodmonkey
goodmonkey's Avatar
Maybe, if I ever get it swapped out and have success with the 330. I've not sourced the code for the RNS yet though, or pulled it from the car. Lots going on around here without working on vehicles.
Old March 11th, 2019, 14:52   #10
MattRabbit
Looks like a great car! Let me know about the RCD-330. My wife has a Beetle TDI that would benefit from one of these (though using Carplay instead of Android Auto).
I also just bought a white VW. I got a Golf SE TDI with lighting package @43K miles in January. So far I really like it. I thought I would miss my ALH, but other than the occasional pang of regret, I'm really enjoying the new car.
enjoy the Passat!
2015 Golf SE TDI (Mine!)
2014 Beetle TDI (Wife's car!)
1981 Rabbit Diesel (Purchased new by my parents when I was 7. I still own it)
http://matt_lisa.home.sprynet.com/
MattRabbit is offline   Reply With Quote
Old April 2nd, 2019, 19:44   #11
goodmonkey
goodmonkey's Avatar
Thanks! My previous experience with the RCD-330 was mostly positive, though the mic location isn't the best it was still usable. That was in an A5 though. The Carplay models are are a little cheaper than the ones with Android Auto, or they were when I bought mine. Still have to install it.
Old August 2nd, 2019, 09:55   #12
htmiser
Hi there! I just bought a white 2014 SEL with 30k miles and warranty from Northern VA. So far, so good; I love it!
htmiser is offline   Reply With Quote
Old August 2nd, 2019, 10:04   #13
JELLOWSUBMARINE
very nice, I wish they came with a wagon
Old August 16th, 2019, 19:02   #14
goodmonkey
goodmonkey's Avatar
I do too, but understand why they didn't. Going forward it is almost amazing anyone makes cars and not all SUVs and trucks for the NA market.
2014 Passat TDI SEL Economy johnnyrotten TDI Fuel Economy 3 July 31st, 2016 16:24
First diesel car ever. 2014 TDI SEL premium johnjonfenomenon VW Passat Family (NMS and B7) TDIs (2012+) 8 October 4th, 2014 16:44
New Member, New 2014 Passat TDI SEL miketheshark VW Passat Family (NMS and B7) TDIs (2012+) 10 September 11th, 2014 13:26
New car: 2014 Passat TDI SEL / My introduction klarowe VW Passat Family (NMS and B7) TDIs (2012+) 15 September 10th, 2014 11:11
2014 Passat TDI SEL JonLla84 VW Passat Family (NMS and B7) TDIs (2012+) 28 August 19th, 2014 14:04
Page generated in 0.15667 seconds with 10 queries
[Output: 128.85 Kb. compressed to 108.03 Kb. by saving 20.82 Kb. (16.16%)]
