Old June 2nd, 2010, 04:01   #61
Diesel_Benz
Banned
TDI(s): Mercedes
Fuel Economy: 28mpg
Originally Posted by TDIMeister
There is no damn way to catch every thread and every post about defeating emission controls and other illegal activity.
All it takes is one moderator 10 minutes a day to scan through the new posts. You don't need to rely on snitches to do your work.
Diesel_Benz is offline   Reply With Quote
Old September 12th, 2010, 12:05   #62
jonnyptdi
Fuel Economy: 45-50ish
hi guys im new to the diesel tuning dont really no much bout tuning diesels? i have a 94 1.9tdi golf 1z engine,im wanting to get more power & performance out of it,any ideas & mods would be appreicated,ive seen the ervy mod but dont understand it? what is the mod done with? any help would be appreciated
jonnyptdi is offline   Reply With Quote
Old February 9th, 2013, 08:11   #63
freebee
freebee's Avatar
Fuel Economy: 50 miles per gal./ 160,000 miles
Default 97 TDI Jetta. Brakes, Clutch,
Hellol, I just replaced the Slave. Master bake and master clutch on my 97 Jetta. I would like to know the proper flushing and bleeding of lines after replacing. Thank you in advance
freebee is offline   Reply With Quote
Old February 13th, 2013, 18:44   #64
Straxcla
TDI(s): 2000 Beetle
Hey, I've got a 2000 tdi beetle and I wanted to push a little more power outa the little guy. What are some common mods and what are the price ranges, and how much of an effect will they have on my mpg?
Straxcla is offline   Reply With Quote
Old February 17th, 2013, 08:32   #65
cordellguentner
Default egr delete kit
I was wondering if you guys have ordered egr delete kits. If so where did you get them from because I can't seem to find a site that has any. I have a 2003 VW Beetle TDI. Thanks for the help!
cordellguentner is offline   Reply With Quote
Old March 13th, 2013, 11:06   #66
The4ork
The4ork's Avatar
hey im just looking for a FAQ on what all the terms about the pumps mean.
like, whats the difference between a 10mm and 11mm pump. I mean, what part is actually 10 or 11mm? and what pump do i have? and should i get an 11mm pump? and such questions as these.
thanks
The4ork is offline   Reply With Quote
Old May 8th, 2013, 00:24   #67
mirulu
mirulu's Avatar
Hi guys, fast qestion
Is this pressure sensor 4 Bar senzor?
Bosch 0281002655
I can't find it anywhere. Thank's a lot.
Milan
mirulu is offline   Reply With Quote
Old May 11th, 2013, 20:50   #68
loudspl
loudspl's Avatar
TDI(s): 02 ASV
Fuel Economy: lolz
Bosch 0281002655
Milan
Bosch 4 Bar MAP should be Bosch 0281006060 or VAG 03K906051
If you prefer Ebay:
http://www.ebay.com/itm/VW-4-BAR-MAP...30753173238%26
02 Jetta, 17:1 CR 81mm ASV, block girdle, ported head, custom Colt cam, IE rods, TT springs, cryo gears, Peloquin LSD, Raxles, FueLab Prodigy pump, 12mm/DE143, HFLOX 5 x 0.013, R32 intake, NX nitrous, 6+6 billet BatMo turbo, Bilstein PSS9 coilovers, BFI mounts
MKVII GTI 6MT, full build, 525hp daily driver. Soon EFR 9174 or PT 6870
loudspl is offline   Reply With Quote
Old May 12th, 2013, 00:13   #69
mirulu
mirulu's Avatar
I know, but my friend has it and I have to calibrate it
Old July 4th, 2013, 20:03   #70
turbotorq
turbotorq's Avatar
TDI(s): 04 Jetta TDI
Fuel Economy: 45ish
2004 pd tdi jetta overboost
My tdi is over boosting at 17.3 PSI for a dangerous number of seconds, also my duty cycle on the 011 log starts at 98% and quickly crashes to 5% . What on earth is happening to my tdi. I hear of clogged vanes or actuator rusted out. Also I just had an underboost code show up. I'm obviously plaged with limp
Mode at WOT and even moderate acceleration up steep hills. Turbo is making screaming noise near redline, I notice its louder even at idle. PLEASE HELP.
turbotorq is online now   Reply With Quote
Old July 15th, 2013, 12:53   #71
DieselburnerA6
DieselburnerA6's Avatar
Fuel Economy: Not interested..
Hi, what maximum boost can do GTB2056vk? And what is stock boost on 3.0tdi? Thanx.
DieselburnerA6 is offline   Reply With Quote
Old October 22nd, 2013, 10:31   #72
ivebeengruvn
Fuel Economy: 42/50
what can i do in a chip to help with mpg s i just want to look at a already tested type of chip or the best one for an alh 2001 golf tdi gls which is my baby for life.
ivebeengruvn is offline   Reply With Quote
Old March 23rd, 2014, 14:54   #73
margus014
TDI(s): Golf 4, 81kw
What is the difference in thease bearing shells:
038105701A
038105701A 007 (yellow)
Can I use ASV engine stock conrod bolt (028105425C) in ARL conrod (original bolt 045105425)?
margus014 is offline   Reply With Quote
Old April 30th, 2014, 13:57   #74
duke21
TDI(s): 2.0 TDI BMN
Fuel Economy: 7.0L/100km
how to post pics please?
duke21 is offline   Reply With Quote
Old June 12th, 2014, 08:59   #75
mpgs
TDI(s): 2009 jsw tdi
Default nozzels
2009 jetta wagon malone stage 2 turbo back exhaust eibach lowered are there bigger nozzels looking for more power goin for stage three and 170 vnt soon but want to change nozzels first help?anybody
mpgs is offline   Reply With Quote
Page generated in 0.16386 seconds with 9 queries
[Output: 118.90 Kb. compressed to 98.38 Kb. by saving 20.53 Kb. (17.26%)]
