Old May 1st, 2005, 02:37   #16
vincenzotdi90
Default chip tuning or obd tuning???
Hi, i've a problem i've already posted a question in this formum but i don't have reply.
Pheraps someone can help me....
I've an ibiza tdi 90 AGR motor i would chip it, but on ebay i've found another ecu ecm with same number but last 2 letter are different:
code 038 906 018 EC (mine eprom) and 038 906 018 L the other eprom.
I would buy this ecu and then remap it, but someone know if 038 906 018 L for ALH motor is compatible with my car???
I've another question i've VAG-COM software ,i've already close egr valve :-), but in ross tech page i've found that is possible boost the engine changing injiction timing in advance.What is better OBD tuning or chip tuning?
I have had powerbox but i don't like it too problem!!
vincenzotdi90 is offline   Reply With Quote
Old May 1st, 2005, 05:27   #17
VelvetFoot
VelvetFoot's Avatar
Default Re: chip tuning or obd tuning???
OBD changes timing equally over entire range - it shifts the curve. Tuning changes the curve.
VelvetFoot is offline   Reply With Quote
Old May 1st, 2005, 08:44   #18
Kabin
Fuel Economy: 51.4 mpg (best)
True TDI OBD tuning is available abroad (not in the states yet) and has the same potential as chip tuning since it potentially accesses the same areas of program space. In the end, each solution is based on the tuner's ability.
Kabin is offline   Reply With Quote
Old May 1st, 2005, 10:51   #19
vincenzotdi90
On ebay i've found obd tuning for my car but is expensive, in ross tech page i've found that with vag-com software is possible change injiction timing and shift the curve, but is very dangerous and i don't know the exact procedure....
I've tryd to change fuel injectdet parameter but i don't see the difference..
Old September 30th, 2005, 10:12   #20
daggychap
Default upsolute chips
How much of a dent does a chip put into the fuel economy of a Tdi? Afterall it seems you cannot get something for nothing, and you would have to credit the engineers at VW with having gone through this pretty thoroughly.
daggychap is offline   Reply With Quote
Old September 30th, 2005, 10:29   #21
BleachedBora
BleachedBora's Avatar
Default Re: upsolute chips
If you use the chip, more fuel = less economy. If you don't use the chip and baby the car you will get better economy.
It's that simple!
-BB
PS I do have an Upsolute stage II chip for sale--contact me if interested. It has 2 Months and ~$10,000 miles of use on it.
BleachedBora is offline   Reply With Quote
Old October 30th, 2005, 14:06   #22
JAVORB
Fuel Economy: 42
i have a seat alhambra 1.9tdi 110hp ,i purchased a tuning box and have had it for 2 years ,in april this year i started selling them on ebay please take a look-http://stores.ebay.co.uk/DIESEL-TUNING-UNITS_W0QQsspagenameZMEQ3aFQ3aSTQQtZkm
JAVORB is offline   Reply With Quote
Old November 18th, 2005, 13:15   #23
PoorMan
Default ECU Hunt
Hi everyone, I hope this post is in the right place, and it hasn't been covered before. I've searched for about 30 minutes and haven't found anything too similar: I've got an 05 Jetta wagon (not the 05 1/2) and am very interested in chipping it. Unfortunately, that means removing the ECU and shipping it out. Could someone tell me where this beast lives, what it looks like, and how to remove it; or direct me to an existing thread that covers this? Thanks very much!
PoorMan is offline   Reply With Quote
Old November 18th, 2005, 13:28   #24
4vdubs
4vdubs's Avatar
Fuel Economy: 47 - 53
I don't know if the 2005 is different, but this link says it is for 2000+ Jetta. This is what I used for my 2003 Jetta. Good luck. http://www.goapr.com/VW/support/ecu_..._gti_jetta.pdf
4vdubs is offline   Reply With Quote
Old November 18th, 2005, 17:02   #25
PoorMan
Default ECU fun!
Thank you very much, 4vdubs!
Old November 27th, 2005, 16:11   #26
Bigjim138
Fuel Economy: depends on the right foot ;)
Thanks 4vdubs, now I know how to remove my ECU when I am ready for the RC stage 3/4!!! not as hard as I thought.
Bigjim138 is offline   Reply With Quote
Old November 28th, 2005, 17:21   #27
4vdubs
4vdubs's Avatar
The hardest part is getting the windshield wiper arm off, a puller helps. I only had to remove one of the arms to get to the ecu.
Old February 6th, 2006, 20:05   #28
superqwik
Fuel Economy: 38-45
man it seems like me and about a hundred other people have purchased a new tdi this month!! anyway here goes first and foremost a big thanks to fred for this site!! I recently purchased a 2005 passat sedan gls loaded.TDI 2.0 11,000 old lady miles on it. looking to chip and add the provent system alchemy posted to it. do you think the provent is a must? not looking to pull my intake, ever. can i chip the PD motor? thanks for the help
seizure,
superqwik
2005 passat 2.0 tdi (mine)
2003 mercedes benz slk 230 kompressor hardtop conv. (hers)
superqwik is offline   Reply With Quote
Old March 19th, 2006, 08:44   #29
gardentender
RIP, Gone But Not Forgotten
Fuel Economy: 53+/46/41
considering the difficulties (described above) in removing the ECU to install a chip,
i am wondering if it would be simpler just to put in better fuel injectors.
maybe cheaper, too?
looking for a modest power increase in the 60-90 mph range. not too big an MPG hit if driven moderately.
i have a 2001 Jetta GL 1.9T, with manual transmission, and approaching 200K miles, 47-50 MPG consistently.
i put a Pierburg MAF in it at about 100K, works like a charm, and seems to have pushed the peak torque about 250-300 rpm to the right.
basic question: chip or injectors, cost/ease?
. . . on the bus.
gardentender is offline   Reply With Quote
Old March 19th, 2006, 23:02   #30
Mike_M
Mike_M's Avatar
Fuel Economy: 56/47/41
maybe cheaper, too?
Simpler, and in the short term, just about as effective as a stage 1 chip. However, modding is an addiction. Shortly, you'll need both. (Or, more likely, injectors and a Stage 2 or 3 chip.)
I recommend Kerma PowerPlus 520s. I have them (no other mods of note, see my signature) and the thing pulls like a freight train from 60-90. No driveability problems, a small amount of smoke on cold-start (only because my intake is clogged pretty badly), and no hit on MPGs...I actually expect to net a GAIN in fuel economy.
For ease, injectors are a no-brainer. I wouldn't try putting in the nozzles myself, but rather I had Lubrication Specialists put the nozzles into good injector bodies and send them to you for installation, then you send your old injectors back. Very simple operation.
As far as chipping, if you have an Upsolute dealer nearby, or are anywhere near PA (and therefore RocketChip), having it done "in person" is very easy, even easier than injectors. However, taking it out and sending it in to be done...only you can decide where that rates on the difficulty scale. I won't do it. But, hopefully there will be more RocketChip dealers very soon, and I won't have to.
Another option, if you want more power with simplicity, is a tuning box. Although you won't quite get performance equal to a "chipping", you'll see a gain. The Diesel Power box seems to be favored around here, and JoeHafner sounds like a quality guy and overall good vendor to deal with. Check out his product.
Mike
2002 Jetta GLS & 2003 Golf GL, for sale soon!
2010 Golf, white 2-door, 6-speed stick, 8k miles, avg 42MPG, SHINY!
Mike_M is offline   Reply With Quote
Page generated in 0.18245 seconds with 9 queries
[Output: 122.28 Kb. compressed to 101.66 Kb. by saving 20.62 Kb. (16.86%)]
