Old July 7th, 2008, 09:00   #16
rdkern
Fuel Economy: A4 = wife drives it, don't know
Originally Posted by cgrillmair
I checked my red/black/blue hose pressures this morning. I don't get instant boost to 12 psi at 2500 RPM and 3rd gear and flooring it, but rather only 9 or 10. I have to wait till I get to > 3500 RPM before I'm getting 12 PSI. Red and black hoses give almost identical results, leading me to believe that most of the intake system is ok. However, my blue hose yields 0 PSI under all conditions. I'm slowly coming to grips with the possiblity that there may be something wrong with the turbo, and why the guy sold it to me at blue book (when all other high-mpg small cars are rapidly increasing in value)...
Carl
The blue hose should get pressure when the N75 is being used, which is when the ecu is trying to cut boost. Not getting any pressure there indicates to me that the N75 is likely your problem. I'd replace all of these hoses, since they are 10 years old and really don't own you anything else, and if that doesn't do the job, replace the N75. I assume you don't have a VagCom, since I believe you can "cycle" the N75 and do some testing with it.
Whitedog's in progress no-start link. http://forums.tdiclub.com/showthread.php?t=199398
Read all about it!
rdkern is offline   Reply With Quote
Old July 8th, 2008, 13:42   #17
rcoker
rcoker's Avatar
Default telling what engine I have...
I just aquired a 96 Passat TDI (traded my 66 beetle for it), and need to know if it has an 1Z or and AHU? How do I tell! Any input would be great!
rcoker is offline   Reply With Quote
Old July 8th, 2008, 16:01   #18
rdkern
Almost certainly a 1Z. Most Passats had 1z's with the AHU's coming in on some of the last ones, and some of the A3's.
Read all about it!
Old October 17th, 2008, 02:11   #19
tdijim
Help, please, if you can. Are in-dash electrical burning smells, sizzling sounds, dome, sun roof, rear-defogger shorting out problems covered anywhere? After this happened, the car sizzled when the key was turned and then wouldn't turn over. I'm guessing the infamous pure copper VW wiring on my B4 is producing a direct short inside my dash. Any advice?
tdijim is offline   Reply With Quote
Old January 19th, 2010, 21:29   #20
Kirk Nordstrom
Fuel Economy: 35-55 mpg Imperial
Question How do I determine which TDI engine I have?
Naive question, I know, but all the same, I'd like to know how to find out which series of 1.9 I have. Vehicle is a 1998 Jetta TDI 5 spd Sedan. Kirk
Kirk Nordstrom is offline   Reply With Quote
Old January 20th, 2010, 08:15   #21
rdkern
A 98 Jetta should be the A3 body style, and probably AHU engine, although with this age car, it could be a 1Z. Precious little difference in the engines.
Read all about it!
Old January 20th, 2010, 12:59   #22
slam
Fuel Economy: 40
The only big difference I am seeing between the 1Z and AHU motors is in some of the injector pump parts. =)
Hey rdkern, I finally got my ebay vagcom cable! I went to pull my injector pump (yes, finally!) and realized I will also need the cam lock tool and probably a belt tensioner. Ah, the VW learning curve. =)
slam is offline   Reply With Quote
Old January 20th, 2010, 13:16   #23
rdkern
Aren't there also slightly different valve stems? could be misremembering there.
Read all about it!
Old April 6th, 2011, 23:11   #24
Gawd129
Gawd129's Avatar
Fuel Economy: 45 MPG
I have an issue with my '96 MKIII that seems like someone must have dealt with it before, but I'm not sure whether to classify it "Frequent", but I thought it entertaining/annoying enough to ask.
I'm having some kind of electronics issue. All at once, my power locks, sunroof, and fan don't work, and the radio turns off and on every time a hit a bump or pull on the E-brake just enough for the car to register it. The instigator of this was that my power lock button fell off, and before i was able to put it back on, i believe i pressed both the "Lock" and "Unlock" buttons at the same time, effectively frying something, but i've checked the fuses and replaced a couple just to try buy they appear fine.
I think this combination of problems points to one specific thing, but I'm yet to find out what it is. Anyone seen this before?
ThankS!
My car is a vegetarian.
Last edited by Gawd129; April 6th, 2011 at 23:12. Reason: Adding model year - 1996 Jetta
Gawd129 is offline   Reply With Quote
Old April 7th, 2011, 09:15   #25
rdkern
Is this a tdi? I didn't think they were offered in the US until 97.
I'd start by cleaning all of the grounds. While you're looking around, you might find something else. But cleaning the grounds can't hurt. I'm not sure where they placed them in the A3, but in the B4 big ones are right near the battery and near the windshield washer fluid. Remove the boost hose if you want easy access.
Read all about it!
Old April 7th, 2011, 15:53   #26
Gawd129
Gawd129's Avatar
Ah, i probably should have mentioned that it's got an A2 1.6 NA swap in it. Thanks for the advice, i'll go attack the grounds right now.
Old November 21st, 2011, 22:44   #27
GTSLOW
GTSLOW's Avatar
How can you tell if you're a 1Z or AAZ? Rock auto has two different lines of parts for each????
'15 Golf Sportwagen S M6
'04 Golf M5 - Koni STR.T's,H&R OE Sports, & Buzzken 2.5" Exhaust
'12 Jetta M6 - Sold back 6/29/17
'15 Passat SE M6 - Sold back 12/22/16
GTSLOW is online now   Reply With Quote
Old November 22nd, 2011, 10:17   #28
slam
Fuel Economy: 40
Generally speaking if it's a '96 it's a 1Z, and '98 and up it's an AHU. '97 was a bit of a mix if I recall correctly. AAZs only came in much later models if I recall correctly.
"The 1996 1Z has no water jacketed heat exchanger on the EGR, a "T" in the fuel line returning from the fuel pump to the fuel filter thermal valve, a "fuel injector for catalyst" solenoid pump attached to the rear side of the air filter box, and a 1Z on the build sticker. The AHU has a water cooler, no T, no 5th injector pump, and a 1Z on the build sticker."
http://forums.tdiclub.com/showthread...=208197&page=3
Old November 22nd, 2011, 10:39   #29
rdkern
AAZ was in the TD's in Canada prior to the 1Z. If it's an NA, it's not 1Z. Might be something pre-AAZ for all I know, since I though the AAZ was 1.9.
Read all about it!
Old November 22nd, 2011, 12:42   #30
loganbmx4gt
loganbmx4gt's Avatar
AAZ was a mechanical 1.9 Turbo Diesel.
loganbmx4gt is offline   Reply With Quote
Page generated in 0.14489 seconds with 9 queries
[Output: 123.44 Kb. compressed to 101.93 Kb. by saving 21.51 Kb. (17.42%)]
