Old March 8th, 2018, 10:31   #1
BigTurboAlh
Fuel Economy: 35
Default Ranger cooling questions
Anyone drill and tap head at the front of the head to let air out when filling coolant? And Iíve deleted coolant globe and lower thermostat. I went with a inline thermostat at the head side. Is there any issues with doing that?
2000 ranger alh swap daily driven
dual valve springs, pistons flycut and decompressed, arp rod bolts main studs head studs, h beam rods, pnp, frank06 cam and oil pump, fueled, sb drag clutch, fass 150, hx30-hx40 compound, nx water meth kit, special injectors, 11mm pump, 3.5in downpipe to 4in rest of the way back.
BigTurboAlh is offline   Reply With Quote
Old March 8th, 2018, 11:26   #2
Exenos
TDI(s): 02 Golf
I think hassenwerk had something in his conversion thread about this. Maybe check that out.
Exenos is offline   Reply With Quote
Old March 8th, 2018, 12:46   #3
Hasenwerk
Hasenwerk's Avatar
My issue was a failed head gasket. Since I have installed head studs I have not had an issue.
I have the stock t-stat and used the MK4 coolant bottle and a MK3 radiator - the Ford overflow tank is removed from the system.
All works well.
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
Ranger BigTurboAlh TDI Conversions 2 August 15th, 2017 11:19
Cooling system r&r questions BEW fruitcakesa TDI 101 5 March 31st, 2015 19:12
Couple of heating and cooling questions--non climatronic pparks1 VW Passat Family (NMS and B7) TDIs (2012+) 0 September 17th, 2013 08:02
Radiator cooling fan and A/C questions Grovrr VW MKIV-A4 TDIs (VE and PD) 3 June 19th, 2006 08:02
Cooling System Questions ladysmithgwl VW MKIV-A4 TDIs (VE and PD) 28 January 20th, 2002 15:39
Page generated in 0.13256 seconds with 10 queries
[Output: 57.59 Kb. compressed to 52.24 Kb. by saving 5.36 Kb. (9.30%)]
