Old March 8th, 2018, 11:21   #1
Momentslater
Fuel Economy: 43/54mpg
Default Broken Injector Fuel Return Nipple
NY cylinder 2 injector decided it didn't want to come out of my old head and caused a bit of grief trying to get it out. Well I got it out but I broke off one of the fuel return nipples. It's on the left side of the injector so I can put it in cylinder 1 but how would I go about blocking that hole off so fuel doesnt go everywhere?
Momentslater is offline   Reply With Quote
Old March 8th, 2018, 14:06   #2
Momentslater
I just found a screw that fit the hole and screwed it in. No problems now.
Old March 8th, 2018, 14:28   #3
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
I'm thinking maybe it needs to drain the injector. Tedious repair no doubt.
Old March 8th, 2018, 17:22   #4
burn_your_money
You can get replacement nipples. JB Weld will also work to seal it shut and then just use it on the end like you are.
burn_your_money is offline   Reply With Quote
Old March 10th, 2018, 10:43   #5
flee
Fuel Economy: 40-ish
When I sent DBW an injector body with a broken nipple he vetoed it.
I found a good used one on ebay for about $50.
2002 Jetta GLS TDI wagon
flee is online now   Reply With Quote
Brand new #1/2/4 Injector With Broken Return Nipple G60ING Private TDI Items for Sale/Wanted 6 September 25th, 2012 17:51
would anyone have a spare injectore (broken return nipple) GuyGuy Ontario 0 July 24th, 2012 14:13
Broken fuel return line--augh! sisyphus TDI 101 4 January 17th, 2009 15:40
Part number needed, fuel return nipple cap daBooj VW MKIV-A4 TDIs (VE and PD) 2 August 15th, 2006 09:52
Broken Nipple on Injector #3 kcb VW MKIV-A4 TDIs (VE and PD) 7 June 16th, 2005 20:53
Page generated in 0.09532 seconds with 10 queries
[Output: 67.17 Kb. compressed to 59.27 Kb. by saving 7.89 Kb. (11.75%)]
