Old March 8th, 2018, 08:25   #1
gq1
Default B4 Wagon smoking when up to temp and losing coolant
Hey guys, I found a B4 wagon glx for sale that has a tdi swap in it from the same year.
The guy says it isn't burning oil but is smoking and going through coolant. Thinks it might be the head gasket. Also says it has a squeaky pulley. Says he rebuilt the turbo system but doesn't have the front splitter on it right now cause the old one cracked apart.
I'm not familiar with TDIs but looking to get into the game. Wondering if this could be a simple fix or if I'm best to keep looking elsewhere before sinking a ton of money into a sinking ship.
275k on body and 175k on tdi swap.
I'm going to holler back at him and try to get more information about the car as possible.
Any input would be greatly appreciated.
gq1 is offline   Reply With Quote
Old March 8th, 2018, 11:15   #2
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
If it's crazy cheap given the issues, then go for it.
Otherwise keep searching.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old March 8th, 2018, 11:38   #3
gq1
Windex- they are asking 2500. Figured it might be a little high considering, I don't know what it would cost to get the kinks out.
Old March 8th, 2018, 12:01   #4
Windex
Windex's Avatar
Coolant smoke will smell a little sweet, oil smoke does not, and has a bluish tinge.
I would max out at $1000 on a car like that, given that you would be assuming the risk on the repair costs.
Old March 8th, 2018, 22:12   #5
Steve Addy
TDI(s): 97 Mk3
IMO That's really way too much for something that has those problems. First you have to work through the problems and second you have to see whether the conversion was done properly and if not you have to go back and fix all that.
I'm in the same boat with Windex, $1000 max and that's just because it's a Texas car with what is likely a reasonably good body.
Steve
97 Jetta TDI, 90 B3V TDI, 92 MB 300SD
You didn't poison the coffee, did you? Not anymore than I usually do.
Steve Addy is online now   Reply With Quote
Old March 9th, 2018, 11:23   #6
gq1
Steve & Windex, thanks for the input. KBB values it at most $1500 and that running properly.
Like y'all said, it would have to be around a grand for me to take that risk.
Old March 12th, 2018, 12:03   #7
Steve Addy
TDI(s): 97 Mk3
I don't trust any book values for these things, especially wagons. The utility of the wagon can add significant value beyond what KBB, Edmunds or NADA like to account for. I take what any of these alleged 'specialists' offer up as accurate pricing info as questionable.
A good wagon is hard to find, but in this case it's a conversion so there's a lot of ways it could be messed up because the conversion wasn't thorough.
I have read on Vortex about people converting VR6 cars from AT to MT without going to the effort of extracting the AT wiring harness and TCU, which is unacceptable to me. The car should not reflect any of the old systems that are now disable simply due to the confusion it causes if someone needs to work on it again. It needs to be a clean slate and accurate. Most Vortex kids don't want to do that, they just want it done.
This could be a very decent conversion or it could be a mess. If I had to wager from the armchair I'd wager on mess, but that's where the inspection comes into play. It's pretty simple to look under the hood and in a couple minutes decide if they did it right or did it wrong.
Without an inspection I'm still at $1000 just because wagon. If it was done right then even with the potential head gasket situation I might be convinced to move a little, but again that would depend on what I found under the hood and other qualitative things like paint or interior cleanliness.
Steve
B4 still losing coolant jcrad VW MKIII-A3/B4 TDIs 10 June 12th, 2013 20:54
B4 Losing Coolant??? jcrad VW MKIII-A3/B4 TDIs 5 March 24th, 2013 09:32
On the road - Need help locating A/C coolant temp sensor on B4 BHarrison TDI 101 9 April 20th, 2007 20:16
Coolant temp sensor location B4 Ray_G VW MKIII-A3/B4 TDIs 5 May 3rd, 2006 09:38
Coolant temp drops. Noticeable motor thump on B4 bigrichard VW MKIII-A3/B4 TDIs 2 October 26th, 2004 10:30
Page generated in 0.13984 seconds with 10 queries
[Output: 80.89 Kb. compressed to 70.22 Kb. by saving 10.67 Kb. (13.19%)]
