Old March 8th, 2018, 06:52   #1
DIRTYMOFO
Default Cylinder head swap
I got a 2005 passat with a BHW, well the alternator belt popped and somehow worked its way into the timing cover and now the engine sounds like it has bent valves. So the question I have is what head will fit my BHW block. A BEW or BRM? Or neither will work?
DIRTYMOFO is offline   Reply With Quote
Old March 8th, 2018, 06:59   #2
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
The BEW has split valve ports, BRM i've heard is the same head. A BHW head will also work of course.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old March 8th, 2018, 15:29   #3
DIRTYMOFO
BRM had the same head as what the BHW?
Old March 8th, 2018, 17:23   #4
Greasemunkey
I lost a timing belt on my ALH but was able to fix it with one valve and two lifters. Well, plus gaskets and bolts etc but that comes with a head swap too.
Greasemunkey is offline   Reply With Quote
Old March 9th, 2018, 16:43   #5
DIRTYMOFO
i pulled the valve cover and i see pieces of lifters and looks like valve seals laying in the head.
Old March 10th, 2018, 14:02   #6
Franko6
Whoops...
I see that I missed the previous post and the fact you had blown out lifters. Lifter bores can be repaired. A picture would help.
The BRM and the BHW cylinder heads are exactly the same. The blocks are different and the head gasket is different (1.9 is 79.5mm piston/ 2.0 is an 81mm piston).Maybe you can get a used head, but maybe it needs more work than the one you have. We usually can fix the one you have and make it better than new.
Figuring out if lifters are damaged and valves bent is not as easy as just pulling the valve cover. That usually won't tell you anything, but if you pull the camshaft out, then you can see if the cam followers are dished, dented, bulged or cracked. We have a very concise 'how to' for removing the cam and then you can plainly see if lifters are damaged. If the lifters are NOT damaged, your valves are good.
Other than that, even if the valves aren't bent, give the BRM about 150,000-180,000 miles, the cam is worn out. We also fix that issue.
Frank's VW TDI's, LLC
1007 Olive St.
Lockwood, MO 65682
417-232-4634
FranksTDIs@sbcglobal.net
'02 80k grey leather, 99.5 R.I.P 153k
'85A2 NA 375k, '91 A3 290k Always Silver, Always a Jetta
Franko6 is offline   Reply With Quote
Old March 11th, 2018, 08:30   #7
DIRTYMOFO
ok Franko6, i will pull the head today, and let you know what I find.
Old March 11th, 2018, 08:47   #8
maxmoo
My appologies to the OP for going off topic but thought someone on here might know the answer to this.....
"Does anybody know if the "ATD" head is identical to a "BEW" head?
I have a nos ATD head, complete with cam and injectors, and was wondering if it will bolt on to a BEW without any issues.
Is everything identical?"
maxmoo is offline   Reply With Quote
Old March 20th, 2018, 13:43   #9
Franko6
As near as I can tell, the ATD, AXR, BEW, BMT engines are the same basic unit. The one stand out feature of the BEW that will make it different than most other PD motors is the valves are recessed, when the BHW, BRM as examples, have valves that project.
1007 Olive St.
Lockwood, MO 65682
417-232-4634
Cylinder head pits in head gasket mating surface glenn1179 VW MKIII-A3/B4 TDIs 16 May 20th, 2013 08:33
ks bare new head wanted local shop ruined my cylinder head sam2007 Private TDI Items for Sale/Wanted 8 October 5th, 2012 14:36
Cylinder head swap issue addressed. 1.9 to 2.0 Scufi TDI Power Enhancements 3 May 4th, 2011 12:47
Getting ready for cylinder head swap mauroper TDI 101 10 July 21st, 2009 06:19
Is cylinder head swap on AHF hard to do? Grunfen VW MKIII-A3/B4 TDIs 1 August 4th, 2008 05:02
Page generated in 0.15004 seconds with 10 queries
[Output: 89.24 Kb. compressed to 76.28 Kb. by saving 12.96 Kb. (14.52%)]
