Old March 8th, 2018, 07:24   #1
jhax
Default MK3 Bose System really worth it?
Good Morning,
I have acquired from the junk yard the bose system from a mk3. I am trying to justify whether or not I should keep it. I have heard mixed reviews about the system. At this point I only have the in-dash tweeters and two 6.5" door speakers. I understand that the output for the Panasonic stereo is 2 ohms per speaker. And I haven't heard good reviews about the stereo in the first place. I would like to be able to use an early mk4 clarion unit (4 ohm output). However, the bose speakers are rated at 2 ohms. I'm thinking the clarion 4 ohm stereo with the bose amplifier and the 2 ohm speakers would blow up the speakers. I would have to run extra wires to the second set of tweeters in the dash. It all just seems like a pain in the butt. Any input or justification would be appreciated.
Thanks,
Justin
jhax is online now   Reply With Quote
Old March 8th, 2018, 09:29   #2
Nevada_TDI
When connecting speakers in parallel the formula to use is (R1 x R2)/(R1 + R2).
If your speakers are 2 ohms each and you parallel them when connecting the amplifier, what you get is (2 x 2) divided by (2 + 2) so 4/4 equals 1 ohm at the amplifier. If you connect your speakers in series then the resistance just adds together; where 2+2 equals 4 ohms.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old March 8th, 2018, 09:59   #3
jhax
That sounds like a lot more work than I want to do. I was hoping to just be able to wire everything up the same as it was in the jetta while retaining my original door speaker connections, here is the wiring diagram for said system. if I wire these in series I essentially would remove the wires from 25 and 26 and combine them with wires going into pins 1 and 2 in the amplifier? Or that cut the ohms in half (ie wiring in parallel)? Series would be removing the wire at 25, connecting that wire to the left rear woofer and removing the wire from pin 2 altogether. Or If I just want to get rid of the amp altogether,
WTB Mk3 Bose radio 00013cave Private TDI Items for Sale/Wanted 4 June 7th, 2016 20:49
PD150 Turbo inlet system worth it? dieselpower04 TDI Power Enhancements 22 August 9th, 2010 15:58
Bose Sound System tmac123 Upgrades (non TDI Engine related) 6 February 8th, 2010 17:08
Monsoon sound system - worth the cash? jlemiski TDI 101 20 October 16th, 2002 21:12
Replacing Bose sound system in Audi 100 Ted General VW Discussion 3 November 5th, 2000 12:49
Page generated in 0.15638 seconds with 10 queries
[Output: 58.25 Kb. compressed to 53.03 Kb. by saving 5.21 Kb. (8.95%)]
