Old March 8th, 2018, 06:14   #1
jhax
Default Fuel cuts out while going up hill
Good Morning Everyone,
I am curious to know why my 96 B4V is doing the following...
I am driving on flat ground at 65mph (cruise on or cruise off). I push the accelerator down and the car speeds up, just like any car should. I get to a long hill, there is a nice one along the I-70 corridor where the front range meets the mountains, still going 65 with cruise on.
Once the car starts climbing the hill, the RPM will hit about 2500 and then drop. The car will slow down to about 60mph (roughly 2250 RPM) and sometimes it hangs out there, sometimes it accelerates again to about 2500 RPM and cuts out again.
I can put the go pedal to the floor and the behavior remains the same. This only happens when going up hill. Other than that the car behaves fine.
Thank You,
Justin
jhax is offline   Reply With Quote
Old March 8th, 2018, 06:58   #2
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
I would suspect a fuel starvation issue, if the low power goes away on its own. If it requires you to cycle the key, it may be limp mode due to a boost problem.
Have you changed the fuel filter lately? Are there bubbles in the clear line going to the injection pump? What is the fuel level when this occurs? have you tried to replicate the problem with a completely full tank?
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old March 8th, 2018, 07:15   #3
jhax
I changed the fuel filter 20k miles ago. No more air bubbles than normal. Full tank, half tank. Once I get to the top of the hill and flattens out everything acts normal. I have never had to cycle the key. Just get to the top of the hill. Would limp mode caused by the turbo go away by its self?
Old March 8th, 2018, 07:25   #4
Windex
Windex's Avatar
No, it would require (at very least) a cycling of the key - off->on. It would also set a code which could be read with VCDS (but not a generic OBDII scanner).
How long after you're going up hill does the power drop?
Can you replicate the power drop on a long gradual acceleration?
I wonder if the pickup in the tank is plugging?
What is a "normal" amount of air bubbles for you? there shouldn't be very many at all.
Trying to understand if this is starvation, if it's an airleak into the line, or a restriction somewhere.
Do you have VCDS or access to it to scan for codes?
Old March 8th, 2018, 08:12   #5
20K is the fuel filter change interval. I'd replace it and see if it solves the problem. You may have gotten some bad fuel that clogged the filter partially.
2002 Jetta wagon, 373K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 286K; '99.5 Golf, 259K; 2011 335d, 56K; 2015 Golf Sportwagen, 10K. Principal, http://www.idparts.com
Old March 8th, 2018, 10:55   #6
jhax
Windex,
I don't find key cycling is necessary. I have never had any codes (I do have a VCDS). I could capture a run on VCDS. Which measuring blocks should I log? As for the amount of time it takes for the RPM to drop, it's a gradual drop down to about 2350 rpm (~60MPH), maybe 3 or 4 seconds from end to end then it starts to gradually accelerate again back up to 65MPH. I have not been able to replicate it on flat ground, although I've tried. Normal being a very small amount that usually occurs. This has been going on since I bought the car. It came with the original fuel hoses and it happened then too. Once there was a split in the hose I replaced them with tygon and the same thing happened.
Peter, this happened post fuel filter change two oil changes ago which leads me to believe that the filter is/was good prior to this thing happening.
Old March 8th, 2018, 11:10   #7
Windex
Windex's Avatar
Interesting - any other symptoms when it happens? Any black smoke?
If not, just a loss of power, I would log boost requested vs actual when the issue is occurring - if the boost actual hits requested, then you almost certainly have a fuel issue - either a restricted supply or a problem with the pump.
Old March 8th, 2018, 11:18   #8
jhax
No other symptoms. Would you happen to know what block that is in VCDS?
Good advice! Thanks!
Old March 8th, 2018, 12:09   #9
Windex
Windex's Avatar
Measuring block 11 if I recall - just look for MAP absolute / requested, and MAP measured - they should follow each other pretty closely, especially if you use the graphing function
Old March 8th, 2018, 12:56   #10
jhax
Will do. I'll post results when I obtain them.
Old March 8th, 2018, 20:13   #11
KLXD
If it's fuel starvation I'm thinking the IQ would increase trying to maintain power???
Log that too while you're at it.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old March 9th, 2018, 08:43   #12
jhax
Okay will do. Thank you.
Old April 9th, 2018, 18:40   #13
jhax
Alright folks here is the MAP log I captured. If I am correct, I started it in a 5th gear pull to as high as the tach would register. I stopped the log and captured again starting from cruise control set at 65mph heading up a hill. I am pretty confident I captured the fuel cut out toward the end of the graph.
Old April 10th, 2018, 09:57   #14
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
I had to recently change my fuel filter due to starvation going up hill (I'm in Denver), and it had only been about 5k miles. Bottom line, we get bad fuel, change filters just like diapers.
2001 Beetle - EGR delete, 01M-ectomy, Atlas skidplate, vented, Frostheater.
I'm not coasting, I'm shifting slowly.
UFO is offline   Reply With Quote
Old April 10th, 2018, 19:01   #15
sootful
Smile
The only time I have had this scenario happen to me was with a bad fuel filter. Once I replaced it, all was good.
sootful is offline   Reply With Quote
Cruise control on down a hill it cuts out out for a millisecond jjpsuperdad VW MKIV-A4 TDIs (VE and PD) 1 December 21st, 2012 16:55
Turbo Cuts off going up a hill? silvergrowler VW MKIV-A4 TDIs (VE and PD) 2 May 3rd, 2009 17:41
fuel cuts out!!!!! enters TDI 101 4 March 24th, 2009 17:19
Engine intermitted skip/ fuel cuts out CTJettaTDI TDI 101 8 January 6th, 2009 13:37
New device saves diesel fuel, cuts pollution pitzel Fuels & Lubricants 12 March 31st, 2003 21:25
Page generated in 0.10627 seconds with 10 queries
[Output: 124.26 Kb. compressed to 103.34 Kb. by saving 20.91 Kb. (16.83%)]
