Old March 8th, 2018, 05:41   #1
TDI(s): 1.9 TDI
Default 1.9 tdi AHF does not work !!!
golf mk1 1.9 tdi AHF 80pin engine swapped (disengaged vehicle 2001 golf), indicator, brain, pedal set, Energies have diesel to enter, but do not give diesel fuel from their nozzles, diesel fuel does not give the necessary pressure. ECU 038 906 018 BM
When we look at the autodata on the diesel pump socket, we can see that the 5 pin is not 12 volts and the 12 volt is not working. When we give 12 volts from the outside, it does not work yet. When we open the cover on the pump or with the sprayer there are 12 volt batteries. canceled immo brain
Where do we need to check for the operation of the tool 109 Is there a complete list, such as roles etc
the masters here say it is not possible I have been working for a long time and I am happy to help you.
I am writing with translator because english is bad.
ahmet38 is offline   Reply With Quote
Old March 8th, 2018, 06:59   #2
TDI(s): 1.9 TDI
Do you need to do something in the electrical system after the immobilizer is canceled?
AHF TDI in the U.S.A.? Mozambiquer VW MKIV-A4 TDIs (VE and PD) 2 December 31st, 2016 13:31
would this setup work? 1.9 tdi AHF dreconx TDI Power Enhancements 6 December 12th, 2016 01:14
Oscillation of the timing on my 1.9 TDi AHF ac.cobra VW MKIV-A4 TDIs (VE and PD) 4 April 15th, 2012 07:46
AHF (110hp) software in AGR (90hp) ECU. Will that work? RomSL TDI Power Enhancements 20 August 8th, 2008 03:16
AHF TDI Engine bradleyj TDI 101 0 February 29th, 2008 08:08
Page generated in 0.12013 seconds with 10 queries
[Output: 50.99 Kb. compressed to 47.10 Kb. by saving 3.89 Kb. (7.63%)]
