Old March 8th, 2018, 05:39   #1
TDI(s): 1.9 TDI
Default 1.9 tdi AFN does not work !!!
golf mk1 1.9 tdi AHF 80pin engine swapped (disengaged vehicle 2001 golf), indicator, brain, pedal set, Energies have diesel to enter, but do not give diesel fuel from their nozzles, diesel fuel does not give the necessary pressure. ECU 038 906 018 BM
When we look at the autodata on the diesel pump socket, we can see that the 5 pin is not 12 volts and the 12 volt is not working. When we give 12 volts from the outside, it does not work yet. When we open the cover on the pump or with the sprayer there are 12 volt batteries. canceled immo brain
Where do we need to check for the operation of the tool 109 Is there a complete list, such as roles etc
the masters here say it is not possible I have been working for a long time and I am happy to help you.
I am writing with translator because english is bad.
ahmet38 is offline   Reply With Quote
1.9 TDI AFN 270hp + 450yfz TDI Power Enhancements 16 July 9th, 2011 06:24
AFN Oil Filter work on an AHU? G60ING VW MKIII-A3/B4 TDIs 2 October 9th, 2009 13:15
Nos on 1.9 TDi AFN evomaster3000 TDI Power Enhancements 24 August 3rd, 2009 19:18
Will pistons from an ALH motor work in an AFN? redmondjp TDI Power Enhancements 2 September 13th, 2005 15:04
TDi 110 (AFN) Stuart_B5_TDi110 TDI 101 6 December 26th, 2004 09:40
Page generated in 0.07896 seconds with 10 queries
[Output: 46.24 Kb. compressed to 43.57 Kb. by saving 2.67 Kb. (5.78%)]
