Old March 8th, 2018, 04:57   #1
Default fuel pump pressure
I am converting a '99 Nissan Frontier with an '04 BEW Mk4. My worry is that the present in tank fuel pump (which I intend to keep) supplies about 52 psi of pressure where the stock VW is only about 10, acting strictly as a pick-up pump. Do I need to worry about installing a return regulator before the fuel filter? Will this higher pressure do any damage to the injection pump seals? Any help is greatly appreciated
conversiondude is offline   Reply With Quote
Old March 8th, 2018, 07:05   #2
TDI(s): 02 Golf
There is no ip on a bew, its all done at the injectors. I'd be inclined to say that since there are no ip seals to blow the pressure would be fine but I cant say for sure.
Exenos is offline   Reply With Quote
Old March 8th, 2018, 12:50   #3
Hasenwerk's Avatar
Not sure how the Nissan does the pressure regulation, but on the Ford Ranger there is a regulator in the fuel tank on the pump asm. This needs to be removed. 52 PSI is way too much pressure - the pump with no regulator will do about 3 or 4 PSI is fine.
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is online now   Reply With Quote
High Pressure Fuel Pump (HPFP) failure - not blamed on fuel birkie VW MKV-A5 Golf/Jettas 80 October 16th, 2014 10:03
Fuel injection pump pressure Boriquakid VW MKIV-A4 TDIs (VE and PD) 4 September 3rd, 2013 07:41
fuel pressure to injector pump 50harleyrider VW MKIII-A3/B4 TDIs 11 November 15th, 2010 11:05
Fuel Pump pressure vwfamilyvan TDI 101 4 April 18th, 2007 22:20
Fuel pump pressure increase BrokenBlock VW MKIV-A4 TDIs (VE and PD) 1 February 16th, 2005 18:01
Page generated in 0.12134 seconds with 10 queries
[Output: 56.69 Kb. compressed to 51.42 Kb. by saving 5.27 Kb. (9.30%)]
