Old March 8th, 2018, 01:30   #1
ben0069's Avatar
Default Acclerator issues
Might be wrong forum but hoping someone can help explain this to me.
I'm having some issues with my accelerator, car is audi allroad
2.5 tdi v6 2004. Lots of mods and mapped.
When I steadily rev up from idle( stationary ), as I hit 2200 revs the revs drop down 400 rpms, but my foot has remained in the same position.
I have looked at data measurement blocks, channel 01
IQ fluctuates between 1.88-2.60
RPM at idle is 745-765
Idle Stabilization at idle fluctuates between 25.00 -26.85 deg kw
when I rev as above and the stabilization reaches 50 deg kw it drops back to 30.
I don't know if this is normal
ben0069 is offline   Reply With Quote
Old March 8th, 2018, 07:40   #2
Is it possible you have turned on the launch control and are not aware of it? And/or you might want to check your clutch switch: I personally went through something very similar and found out my clutch switch was faulty.
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, Stage 4 Custom TDTuning, PP764's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old March 8th, 2018, 11:00   #3
ben0069's Avatar
I don't have launch control on the vehicle, will have to check clutch switch, thanks.
Old March 9th, 2018, 14:32   #4
Hasenwerk's Avatar
I would start with double checking that F, F36 and F47 in the cruise control measuring blocks are all "0" when the brake and clutch pedals are at rest. F and F47 also need to switch at the same time when the brake pedal is pressed.
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
Old March 11th, 2018, 11:08   #5
ben0069's Avatar
Thanks Hasenwerk, I have tried those and they are working ok
Old March 11th, 2018, 18:46   #6
Fuel Economy: 35-45mpg
Does the car drives as it should ? Might be a duff accelerator pedal and messes up drivers wish maps... can you monitor the accelerator pedal whilst doing so against IQ and rpm’s ?
adamss24 is offline   Reply With Quote
Idle issues and shuddering issues. Help! slayer3055 VW MKV-A5 Golf/Jettas 9 May 24th, 2017 12:01
2014 TDI SEL Fuel Issues and High Pressure Fuel Pump Issues khoffman31 VW Passat Family (NMS and B7) TDIs (2012+) 4 March 2nd, 2016 19:05
Thermostat Issues, A/C Issues, and "Logic" Questions AV8RLEO TDI 101 6 July 8th, 2013 18:18
PD150 Studdering issues when high RMP.. Lift Pump issues? tothemax TDI Power Enhancements 14 June 15th, 2013 14:38
09a EYP Vehicle Speed Sensor issues, possibly TCM issues TreyDavis VW MKIV-A4 TDIs (VE and PD) 4 March 14th, 2012 14:40
Page generated in 0.13423 seconds with 10 queries
[Output: 74.50 Kb. compressed to 65.10 Kb. by saving 9.40 Kb. (12.62%)]
