Old March 7th, 2018, 21:58   #1
jesiah
jesiah's Avatar
Default ISO special tool for fuel injection pump in Los Angeles. '03 MK4 TDI
Hey all! FIrst time posting here, but been driving VW diesels for many years now!
I'm in search of the " special tool ", proprietary socket to remove the do not tamper bolt on the fuel injection pump of my 2003 MK4 ALH Jetta TDI. It's part # 0986612605 aka 7mm triangle socket aka ?
Any chance there's someone in the LA area that has one to loan or sell?
I'm visiting my parents outside LA, in Fullerton / Anaheim, so without myvusual resources, and therefore don't think I can grind a 7mm hex to fit... and need to leave by this weekend to get back to work (Portland). Haven't found a place online that can overnight the tool.
The shop that has the seals (RPM) didn't know about getting the special tool besides ordering online.
[The pump is leaking, and before dropping $1.5-2.5k for a mechanic to put in a new/rebuilt one, this seems like a very doable $20 fix (+ Vagcom), according to some great resources I've found in this forum!... if I can find this dang socket.]
Thanks for any help!
jesiah is offline   Reply With Quote
Old March 8th, 2018, 01:28   #2
burn_your_money
Cut a slot in the bolt and use a flat screwdriver. Make sure to mark the lower section (QA) relative to the pump body very well otherwise you'll have a terrible time getting the car running again. If it's just the top seal that's leaking you don't need VCDS.
I buy core TDI pumps. PM me for details
burn_your_money is offline   Reply With Quote
Old March 8th, 2018, 06:21   #3
KLXD
I've got a modded 6 point you're welcome to but I'm in Sunland. Maybe 45 minutes away with no traffic.
Another option is to bang a cheapo 12 point onto the bolt then replace with a standard socket head.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
KLXD is online now   Reply With Quote
Old March 8th, 2018, 06:26   #4
CopaMundial
https://www.idparts.com/metalnerd-in...ool-p-475.html
Welcome to the TDIClub forum. If this community forum helped you save money on a purchase or repairs, please consider donating just a small percentage of what you saved using the 'donate' link HERE. Donations keep the forum going. (note: I'm not affiliated with TDIClub or Fred... I just can't imagine the world without either of them)
CopaMundial is offline   Reply With Quote
Old March 8th, 2018, 13:32   #5
Nevada_TDI
Or if you have a cheapo 7.5 mm socket a couple TAPS at a hammer will set it and it will stay on there
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old March 8th, 2018, 14:24   #6
jesiah
jesiah's Avatar
That's seems doable for me, later today. I'll PM you.
Thanks!
Old March 10th, 2018, 00:53   #7
alex_tdi
Hey I'm in Fullerton and I got the special bit I used to fix my TDI's fuel pump gaskets.
This one: https://www.idparts.com/metalnerd-in...ool-p-475.html
If you're still looking for it, send me a PM. I'll see if I can find it in my garage tomorrow (Sat) and maybe we can figure something out.
Alex
alex_tdi is offline   Reply With Quote
Old March 11th, 2018, 23:31   #8
jesiah
jesiah's Avatar
Alex
Dang wish I'd seen this! Got the bit taken care of, and everything is just about put back together.
Old March 16th, 2018, 10:37   #9
jesiah
jesiah's Avatar
UPDATE:
Success!
Thanks to KLXD for the tool and the various people who've posted how-tos on doing this job.
Took a full day to slowly follow the instructions, pissed off my parent's landlord, but after priming the pump in the morning, it started up and ran smooth. Then drove 1,100 miles from LA to Portland without a hitch (literally). VAG-COM shows the IQ is staying steady at 3.0-3.2 after my initial adjustments.
SO.. if anyone in the Portland area wants to try and save a couple thousand bucks, hit me up! I can either loan you the bit, or I'd be happy to do the seal job, for a better price than any local mechanic (if you can even find one that will do it).
Thanks again, everyone for your input, offers, and help.
ISO special tool for fuel injection pump in Los Angeles. '03 MK4 TDI jesiah West Coast Canada/USA 2 March 11th, 2018 23:38
Any Tdi Fuel Injector Pump Rebuilder in Los Angeles area? fortec General VW Discussion 7 March 23rd, 2009 12:07
Anything Special to Change out Fuel Injection pump Cstowell20 TDI 101 24 April 13th, 2008 09:45
ISO: TDIs in Los Angeles area LABioSearch TDI Cars for Sale/Wanted 4 March 27th, 2005 20:53
Premium Fuel in Los Angeles? TribalMinds Fuels & Lubricants 3 April 20th, 2004 21:22
Page generated in 0.16122 seconds with 10 queries
[Output: 91.81 Kb. compressed to 78.71 Kb. by saving 13.11 Kb. (14.28%)]
