Old March 7th, 2018, 22:40   #1
bigjake
Default BEW intake manifold and EGR cooler
Hey all,
Here in the next few weeks, I plan on tearing apart my engine to clean my nasty intake manifold. My first question is about the small butterfly valves in the manifold. I've heard there's a risk that they can break off and get ingested into the motor. I was curious as to how to remove these. Methods, tools, etc. I also would like to know, does their removal affect performance any? I'm assuming not, but figured I'd ask.
When that's all done and put back together, I plan to address my EGR cooler. Awhile ago I discovered my car was a victim of the botched recall when I found my lower pipe had a crack. I deleted only the lower pipe by placing blanking plates on the exhaust manifold port and on the port on the bottom of the cooler. While the exhaust leak under the hood is gone, my car is struggling to stay at operating temperature outside of the summer months. It's running cold and is killing my fuel economy. I believe this is due to the inoperable EGR. I intend to get a new pipe, reinstall all the hardware and delete the EGR electronically. I've read the electronic deletes will program the computer to keep the EGR valve closed, but open it whenever the car falls below operating temperature. Does anyone know the official term for this delete and someone who can do it? Also, I do not want my new lower EGR pipe to crack. I've read on here that one has to align the cooler to prevent this. How do I go about properly aligning the cooler?
-Jake
bigjake is offline   Reply With Quote
Old March 8th, 2018, 14:03   #2
gforce1108
gforce1108's Avatar
Fuel Economy: Jetta: 44.5 summer / 47 on snows
You are looking for dynamic EGR. I also have problems with low coolant temps after deleting my EGR (also due to the dealer screw up). I believe people rip the butterflies off the manifold, leaving the rod, etc in place. I went PD150 manifold to clean things up - I don't think dynamic EGR existed back then and I wasn't going to buy the replacement flex tube.
There is a pdf posted here on how to properly align the EGR cooler to ensure it won't break again (recall procedure). I'll see if I can find it
I hate rockauto.com http://forums.tdiclub.com/showpost.p...&postcount=236
04 Jetta GLS 5sp - EGR delete, RC3, VNT17/22, 3" turbo back exhaust & 2.5" FMIC+PD150 intake. SBC Stage 2 Endurance w/SMF. Eibach lowering springs
gforce1108 is offline   Reply With Quote
Old March 8th, 2018, 14:06   #3
gforce1108
gforce1108's Avatar
Here you go:
http://pics.tdiclub.com/data/516/m6_campain.pdf
Old March 8th, 2018, 14:31   #4
bigjake
Originally Posted by gforce1108 View Post
Thanks, man! I looked through it. Page 10, part 12...I don't believe I've seen that bracket on my EGR. I'll have to double check, but that would probably explain a lot if it's missing, lol.
So I can literally "rip" the butterflies out of the IM? Are they really that flimsy?
Old March 8th, 2018, 14:48   #5
gforce1108
gforce1108's Avatar
From what I saw, yes. I believe the person who first posted used needle nose pliers to rip them out. And since they have been injected into engines, they must come off fairly easy! I wasn't aware of that problem when I swapped to the PD150 manifold. I also had most of the brackets missing along with some mounting screws.
Old March 8th, 2018, 14:49   #6
gforce1108
gforce1108's Avatar
one thread about the flaps here:
http://forums.tdiclub.com/showthread.php?t=351950
Old March 9th, 2018, 08:18   #7
mjydrafter
mjydrafter's Avatar
The Flaps, grab them with a vise grip and give them a sharp twist. They pop right off. Mine did anyway.
mjydrafter is offline   Reply With Quote
Old March 9th, 2018, 13:55   #8
coalminer16
coalminer16's Avatar
TDI(s): Golf 2004
Fuel Economy: as good as 58 (over 700 miles) and as low as 30 over the same route
They are just tack welded on. I tapped the hole for the shaft and removed those as well as the plastic bushings and threaded a bolt in - sealed the bolt too and plugged the vac booster that ran the butterflies.
Shade Tree Mechanic "I'm too shady to know anything"
1981 Rabbit car 1.9aaz, 5 spd, 1981 Caddy VW truck diesel, 2004 Golf-2 inch lift, -fixing, 2005 Golf-2 inch lift - totaled twice and fixed twice, 2005 Jetta Wagon - 2 inch lift
Originally Posted by rmchambers
I really had no idea that VW dealerships were so awful to go to, they sound like undertakers cos everything that goes in there winds up dead.
coalminer16 is offline   Reply With Quote
Old March 30th, 2018, 15:09   #9
bigjake
Hey guys, I finally got around to doing this. From the PDF file above, it looks like I was missing bolt number 10 on page 10, which looks like it mounts the bracket to either the manifold or the block. That seems to explain my cracked lower pipe. I left the cooler off for now and bypassed the coolant hoses with plumbing elbows.
The manifold was definitely dirty and greasy at the inlets with a little bit of crud, but didn't appear gummed up enough to look like it would hinder performance. I cleaned it using carburetor cleaner and a pressure washer. I also popped off the four butterflies. They themselves weren't flimsy, but they were sort of crimped onto that shaft. A firm pop of the butterflies with needle-nosed pliers took them right off.
After reassembling everything, I test drove it and didn't notice any performance gain which didn't surprise me, given how not clogged it was. Maybe I'll see a slight fuel economy gain but I need to drive out a tank first.
Like I mentioned earlier, I intend to get my EGR functional again in terms of hardware. I plan to do a software delete so my valve stays closed unless the engine falls below operating temperature. My only immediate concern is that, when I reinstall the cooler and add the missing bracket bolt, with my luck, a new $100 lower pipe will crack anyway within a few thousand miles. Does anyone know of any aftermarket lower pipes for purchase that are reinforced and won't crack, even if the cooler is slightly misaligned? Like, one made out of stainless steel or something.
Intake manifold, egr and egr cooler the same between Alh and bew? breakfasteatre VW MKIV-A4 TDIs (VE and PD) 3 January 10th, 2018 05:30
2006 TDI BEW Intake manifold and EGR cooler mutzie Private TDI Items for Sale/Wanted 1 March 22nd, 2015 19:03
WTB 2006 TDI BEW Used Intake manifold and EGR cooler mutzie Private TDI Items for Sale/Wanted 0 March 22nd, 2015 17:08
F/S Bew EGR , EGR cooler, Throttle Body and/or Intake Manifold F/S Spätzle Burner Private TDI Items for Sale/Wanted 2 July 6th, 2013 10:04
BEW Vacuum Pods for EGR cooler and Intake Manifold lucforce Private TDI Items for Sale/Wanted 2 February 20th, 2012 07:21
Page generated in 0.16423 seconds with 10 queries
[Output: 97.09 Kb. compressed to 83.75 Kb. by saving 13.34 Kb. (13.74%)]
