Old March 7th, 2018, 18:43   #1
VIPNiSS
TDI(s): MK4
Default Best option to DELETE EGR and KEEP ASV
Hey guys does anyone make any kits to make this possible? I would like to delete the EGR but retain the function of an ASV just in case of a runaway.
VIPNiSS is offline   Reply With Quote
Old March 7th, 2018, 18:55   #2
OlyTDI
TDI(s): '04 Golf
Through a tune:
http://forums.tdiclub.com/showthread.php?t=305248
2004 Golf GL PD TDI
Malone Tuned, SBC Stage II Daily, Nicktane Cat 2 fuel filter, Dieselgeek bypass oil filter, Whitedog intake hose fix, A4 Defender skid plate, GLI Recaros, Check Temp III, Ventectomy, LED trunk lighting mod, Volx glass headlight lenses, VR6 front and wagon rear springs. Koni FSDs all around. FrostHeater with bumper mounted plug-in mod (details here).
OlyTDI is offline   Reply With Quote
Old March 7th, 2018, 22:00   #3
ToxicDoc
TDI(s): 2001 Jetta
The dynamic tune seems to be the best option to retain the benefits of the EGR warm up. However, if you just want to shut down all EGR, all you have to do is use a block off plate - no gas enters but the ASV function remains.
ToxicDoc is online now   Reply With Quote
Old March 8th, 2018, 22:17   #4
Momentslater
Fuel Economy: 43/54mpg
All I did was remove the EGR Cooler and bypassed the coolant hoses. I used a crap ton of aluminum foil and sandwiched it in-between the exhaust manifold and the pipe that goes to the EGR cooler. Then I just slapped at piece of aluminum tape onto the bottom of the EGR/ASV and unplugged the vacuum line to the EGR Valve and put a bolt in it. I have an CEL but that can be removed in a tune.
I'd strongly recommend getting a block off plate instead of being "roadkill" with alluminum foil like me. It's pretty ghetto and probably won't last more than a year but it didn't cost me extra.
Momentslater is offline   Reply With Quote
Old March 9th, 2018, 08:56   #5
UFO
UFO's Avatar
TDI(s): 2001 Beetle
Fuel Economy: 50mpg on B100
I plugged the vacuum line to the EGR, and built a circuit to emulate EGR function to the ECM. No CEL, everything else functions normally.
2001 Beetle - EGR delete, 01M-ectomy, Atlas skidplate, vented, Frostheater.
I'm not coasting, I'm shifting slowly.
UFO is online now   Reply With Quote
Old March 9th, 2018, 17:24   #6
csstevej
Ideally a tune would be best, search the MAF twist, it works you won't get a CEL but you need VCDS so you can see what is given verses what is requested. Just my .02
2001 golf auto to 5 speed manual swap,G60/VR6 clutch setup,coolant migration mod.
csstevej is offline   Reply With Quote
Old March 10th, 2018, 07:38   #7
VIPNiSS
TDI(s): MK4
UFO.. can you elaborate or take more pics of this?
Old March 11th, 2018, 12:28   #8
wonneber
What did you do to get the change in air flow that the ECU should pickup?
Old March 11th, 2018, 15:12   #9
Oo-v-oO
Oo-v-oO's Avatar
Search "Epsilonian Device".
-Lee
"Felix qui potuit rerum cognoscere causas"
[Happiness is understanding how things work]
Oo-v-oO is offline   Reply With Quote
ASV after EGR delete olboyowl VW MKIV-A4 TDIs (VE and PD) 3 January 7th, 2018 18:58
ALH turbocharger upgrade, EGR/ASV delete Anita!! TDI Power Enhancements 9 December 5th, 2017 17:08
EGR & ASV delete. Max Mullineaux VW MKIV-A4 TDIs (VE and PD) 9 March 31st, 2017 02:37
EGR/ASV Delete Lilryan TDI Power Enhancements 6 February 7th, 2016 07:42
Page generated in 0.15259 seconds with 10 queries
[Output: 88.56 Kb. compressed to 75.61 Kb. by saving 12.95 Kb. (14.62%)]
