Old March 7th, 2018, 18:11   #1
neimis
Default VCDS scan of Mk7 airbag
I just started using a Ross-Tech micro-can cable, and am wondering if it is safe to scan the Mk7 airbag module.
Reason I'm asking, is that on Mk4's sometimes a scan of the airbag module would set off a permanent airbag light which could not be turned off. My Mk4 has the airbag model which is affected by this, so I never scanned the airbag module. I believe this issue was unique to the Mk4, but I'd like to be certain.
Now I'm hoping to scan my Mk7 - hopefully this isn't an issue with the Mk7's. I'd appreciate it if someone could tell me if it's OK. Thanks
92 Passat TD
01 Golf GL TDI
15 Golf Trendline TDI
neimis is offline   Reply With Quote
Old March 9th, 2018, 13:33   #2
Lightflyer1
Lightflyer1's Avatar
As far as I know that is only a legacy issue. I have scanned my car several times with no ill effects.
2015 Beetle TDI.
Old March 9th, 2018, 16:28   #3
neimis
Thanks, that's what I wanted to know.
92 Passat TD
01 Golf GL TDI
Old March 14th, 2018, 08:25   #4
jef@rosstech
Associate Ross-Tech Vendor
We have details on this topic on our website:
http://www.ross-tech.com/vag-com/vw_issues.html#Airbags
tl/dr version : Software for the last 14 years takes steps to prevent the airbag issue.
Jef blah blah blah
www.Ross-Tech.com
What should you do first with VCDS? AUTOSCAN!
jef@rosstech is offline   Reply With Quote
VCDS scan of Mk7 airbag neimis VW MKVII-Mk7 Golf family including Golf Wagon (~ 2015 +) 1 March 9th, 2018 05:38
VCDS Scan Dasilzar VW B5 Passat TDIs 5 February 1st, 2018 22:56
VCDS scan Lightflyer1 Testing 0 December 4th, 2011 10:48
VCDS scan pete the caveman OBD Scanners 3 April 27th, 2011 13:18
Airbag Light... ok to scan??? alphaseinor OBD Scanners 10 February 11th, 2007 06:05
Page generated in 0.11545 seconds with 10 queries
[Output: 63.27 Kb. compressed to 56.50 Kb. by saving 6.76 Kb. (10.69%)]
