Old March 7th, 2018, 17:27   #1
pontala1@gmail.com
TDI(s): 03 jetta
Default what do I need for an EGR delete?
I have an BEW 04 tdi Jetta it has over 260k miles and it just started to give me some trouble I need replace the heater core and now the the upper intercooler pipe to the EGR (the clip end) is not staying connected it jumps out every time I press on gas not sure if the clip were out that no makes sense it has a little bit of oil on it and I not sure if this is normal?
I figure take the opportunity to remove the EGR, can anyone give me a guide in how to do it the proper way? I would like to get the best mpg possible. I also wonder what would be the cost? Seams like I have to buy a tuner for $300 Or can I buy a $30 OBDII Chip Module on ebay?
I appreciate any help
pontala1@gmail.com is offline   Reply With Quote
Old March 7th, 2018, 17:47   #2
drucifer
Your hose problem can be fixed with a "doggie collar". They're around 40 bucks from kerma or idparts.
Is your egr cooler leaking? Consider the tune to delete or get a dynamic egr tune. You never know if you might move, a subsequent buyer may need the egr or they may change the rules in your area of the state.
drucifer is offline   Reply With Quote
Old March 7th, 2018, 19:50   #3
pontala1@gmail.com
TDI(s): 03 jetta
Thanks for the replay. Thats great information this is the one you are talking about? http://www.fixmyvw.com/the-doggie-co...r-bew-engines/
I think is mine heater core because I smell it inside the car when I turn the heat on also mine windshield is getting grease' I do not see any liquid inside the car but I have to add a 1/2 cup of liquid in about 30 days. I was hopping to be something else but since the windows are getting dirty from inside I am assuming it is due to the heater core.
Old March 7th, 2018, 20:15   #4
drucifer
That is one version. I was suprised AA Rodriguez would sell something with kermatdi on it. Your leaking heater core needs to be fixed sooner than later. If you can't do it soon at least bypass it by conecting the hoses. It's not worth your health breathing those fumes.
Old March 8th, 2018, 12:58   #5
pontala1@gmail.com
TDI(s): 03 jetta
I agree 100% I am waiting to the weather to break I am planing to go to a junk yard and practice remove the dash before I do in mine car. I am on the assumption if I keep the heater set on cold it will not circulate inside the heather-core is that correct? I see this one it has free shipping and they say it will be here sarturday if I order by tonight. https://www.tdiupgrades.com/product-...x-clamp-collar
It should be the same thing correct? or you recommend a different brand?
Old March 8th, 2018, 14:39   #6
drucifer
I've never heard of the company and the design is a little different. I would stick with a known good design from a Comany known for good customer service. Kerma, idparts, fixmyvw are all reputable sources. As far as the junk yard goes if you have the time it would be great train ing session. Make a list of all the little knick nacks you might need. Nuts, bolts, wheel bolts, bolt covers, fuses. A handful of this might be $5 at the yard at least $30 at the parts store let alone the dealer. Buy an oem heater core. You don't want to do it twice.
Old March 8th, 2018, 17:02   #7
pontala1@gmail.com
TDI(s): 03 jetta
Yes sir. I am planing to get a good heathercore it looks like a major job. I appreciate all you help will order it next.
Can you tell me were to buy OEM heatercore for a decent price?
Thanks again
Old March 8th, 2018, 18:05   #8
drucifer
Oem heater cores go for 150 or so. If that's not in your budget I think you should CONSIDER used oem. Full service junk yard $40 but you're
going to pick a part for training, so there's that.
Full serve junk yards can be viewed at car-part.com. there's flea bay but I'm sure you would want to inspect in person for such a critical item. Same core goes in gas or diesel mk4 except 98 beetle. Part #1J1819031B
Non oem cores go for $60 from oem manufacturers. Check the big advertisers here for the particulars
Old March 8th, 2018, 18:16   #9
drucifer
Link from another thead but I do follow humble mechanic
https://www.youtube.com/watch?v=GR6DYOJ3B34
Old March 10th, 2018, 16:12   #10
pontala1@gmail.com
TDI(s): 03 jetta
wow great video! I appreciate it brother I do have foam flying on my eyes time to time and din't know I could fix it. time consuming job but has to be done.
thanks again
WTB: PD150 intake, race pipe, EGR delete, cooler delete Judson Private TDI Items for Sale/Wanted 2 October 16th, 2017 16:27
CR DPF delete, mid pipe, & Darkside EGR delete. GTSLOW Private TDI Items for Sale/Wanted 10 May 29th, 2017 14:23
Page generated in 0.15226 seconds with 10 queries
[Output: 90.79 Kb. compressed to 76.98 Kb. by saving 13.81 Kb. (15.21%)]
