Old March 7th, 2018, 15:34   #1
absalom
absalom's Avatar
TDI(s): none
Default Help identify this strange noise! 2002 ALH
It is present when the car is cold only. It is also accompanied by an odd whooshing sound during deceleration.
http://www.youtube.com/watch?v=14gkO39n_k8
absalom is offline   Reply With Quote
Old March 7th, 2018, 16:50   #2
Sounds like one of the timing belt rollers making noise, or perhaps the serpentine belt tensioner or idler pulley. The timing belt noise when cold is a pretty common thing. I had two belts that did that on my ALH. You may want to remove the timing belt cover and see if you an pinpoint where the noise is coming from. Sometimes it occurs when debris gets on the back side of the belt and rubs off on a roller. Then the roller will make noise when the stuck debris passes over the belt.
How far into the change interval are you? If you're nearing a belt change time you might want to go ahead and do it. If you're not and none of the rollers or tensioner sound like they have bad bearings, then you could let it go. I didn't change my belt early when it happened, and didn't have a problem. But in this case, past performance is no guarantee of future returns. :-)
2002 Jetta wagon, 362K, RC3+; 1993 Mercedes-Benz 300D 2.5, 197K; 1997 Passat, 285K; '99.5 Golf, 257K; 2011 335d, 56K; 2015 Golf Sportwagen, 8K. Principal, http://www.idparts.com
Old March 7th, 2018, 17:06   #3
absalom
absalom's Avatar
TDI(s): none
Good input. I’m 90k into my next change due at 300k. I was initially thinking a piston ring and lost compression as I thought that would explain the noise during decel.
But that wouldn’t make sense because it’s still incredibly powerful with absolutely no power loss. New t-belt it is then. Thanks!!
Old March 7th, 2018, 17:19   #4
absalom
absalom's Avatar
TDI(s): none
Indigo, as I approach 300k, should I just bite the bullet and get the high mileage kit with all the fixins’? Including engine mount, both pulleys, etc?
Old March 7th, 2018, 17:34   #5
It depends on how you've maintained the car. If you've never replaced the front mount, I'd do that. Otherwise the high mileage kit is a good option if you've not replaced the additional components recently. If you have, you're better off with the regular kit and the tensioner and roller studs.
Old March 7th, 2018, 19:12   #6
absalom
absalom's Avatar
TDI(s): none
Just to confirm, you don't suspect a compression/piston rings issue based on this sound?
Old March 7th, 2018, 19:35   #7
wonneber
The cam gear is recommended at 300K miles.
Old March 8th, 2018, 02:16   #8
I don't hear anything that suggests a compression/rings issue.
Old March 8th, 2018, 22:10   #9
Momentslater
Fuel Economy: 43/54mpg
It sounds like it's coming from the back? Maybe an exhaust leak? It sounds like something timing or top end related. I had a similar noise to this just this morning. It was a poorly seated injector in my case.
Momentslater is offline   Reply With Quote
Old March 8th, 2018, 22:21   #10
ToxicDoc
TDI(s): 2001 Jetta
Sounds like the accessory belt. Mine made a very similar sound until I changed to a different brand. I forget which was which.
ToxicDoc is online now   Reply With Quote
Strange noise to identify SPB TDI 101 4 May 12th, 2016 13:25
Strange whine noise from ALH engine will24 VW MKIV-A4 TDIs (VE and PD) 13 March 29th, 2015 15:25
2002 ALH Strange buzzing noise under full boost [with video] Hasenwerk VW MKIV-A4 TDIs (VE and PD) 5 September 22nd, 2014 13:47
Strange humming noise - RPM related Mk4 ALH N519AT TDI 101 10 August 9th, 2012 14:24
2002 ALH TDI, changed the N75 and a strange noise started gioTDI VW MKIV-A4 TDIs (VE and PD) 3 April 8th, 2010 09:44
Page generated in 0.14882 seconds with 10 queries
[Output: 96.32 Kb. compressed to 82.05 Kb. by saving 14.27 Kb. (14.81%)]
