Old March 7th, 2018, 15:11   #1
Ls3ase
Default B4 Passat measurements needed PLEASE :)
Someone with a tdi b4 Passat will you...
Post a screen shot of 002 and 006 measuring blocks in vcds?
Post a screen shot of 011 measuring block when supplying the Ecu with 20lbs pressure w/ a mighty vac or something similar
Measure the turbo actuator pressure when supplying the Ecu with 20lbs of pressure w/ a might vac
Measure the voltage at N75 at 1lb and 20lbs pressure to the Ecu
Pretty please?
Ls3ase is offline   Reply With Quote
B4 Passat Parts Needed! tomo366 Private TDI Items for Sale/Wanted 2 January 3rd, 2018 19:19
1996 B4 Passat help needed Azgrw South Eastern USA 4 July 28th, 2014 08:53
Measurements needed db123 VW B5 Passat TDIs 8 June 5th, 2014 14:42
B4 Passat grill surround needed Ray_G Private TDI Items for Sale/Wanted 1 November 20th, 2005 17:55
Wheel Spacers needed? B4 Passat TribalMinds Upgrades (non TDI Engine related) 6 April 29th, 2003 08:14
Page generated in 0.13965 seconds with 10 queries
[Output: 46.59 Kb. compressed to 43.91 Kb. by saving 2.68 Kb. (5.75%)]
