Old March 7th, 2018, 11:50   #1
Intech
Fuel Economy: 03' Jetta 67.1 best 51 avg. 99.5 Golf 46 Avg.
Default Shifter question
Information needed. On my 99.5 Golf, I found out that it has a Mk3 shifter and linkage, because when I wanted to put an Audi TT short shifter in it, I was told, that while possible, it would not be worth the cost.My question is this:Is it a MK 3 or a MK4 transmission, and if it is a MK3 can a MK4 be bolted in its place?If so, I can than get the Audi shifter
A gun is like a parachute, if you need one and don't have one, you'll probably never need one again
Intech is offline   Reply With Quote
Old March 7th, 2018, 13:11   #2
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
It's a MK4 transmission (02J) with the earlier MK3 (02A) shifter linkage to be precise.
I converted my B4V to the later style 02J shifter, and would do so again in a heartbeat - I found it to be that much more precise.
Note, I also upgraded mine with the TT shifter "golf club" to shorten fore/aft throws (does nothing for side to side)
to convert yours, you would need the shift lever from inside the car and the attached cables, the cable retainer bracket from the top of the transmission, the cable ends, the "golf-club" weight from the top of the transmission and most importantly, the sector/shift shaft that goes down into the transmission. You may also need the vw emblem piece (bottom of the transmission) that the above sector shaft sits in.
These parts are not TDI specific - they can come from any manual 02J jetta or golf.
There are two styles of shifter end as well - pin end and ball-end. The pin end are more common for when you may need replacement parts. Parts can be sourced at almost any junkyard.
A conversion well worth it in my opinion, especially if you are able to do the labor yourself. Others think not.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old March 7th, 2018, 15:29   #3
Intech
A super thank you, and I will not be doing the work. However, I now know what has to be done, and will proceed to do it as soon as possible. Again thank you very much
Old March 7th, 2018, 16:41   #4
RexNICO
TDI(s): None
... These parts are not TDI specific - they can come from any manual 02J jetta or golf.
As noted, these are not TDI specific parts, so you would have more luck finding used parts for the conversion over on the vortex.
Good luck
Recently relocated from OH to GA, let the warm weather begin!
VW/Audi Auto-dim Rear view mirror FS
RexNICO is offline   Reply With Quote
Old March 8th, 2018, 02:22   #5
Intech
Good luck
Good point, thank you
Old March 8th, 2018, 05:20   #6
Windex
Windex's Avatar
One more thing - the connector for the reverse lamp switch is different - you would need to get one of those to replace the one in your car to make the reverse lamps work again after the swap.
Old March 8th, 2018, 11:02   #7
RexNICO
TDI(s): None
Good point.
OP - here's a set-up I had for sale about a year ago, but it has SOLD
http://forums.vwvortex.com/showthrea...mp-shift-tower
NOTE: the shift tower is not pictured in that thread.
Old March 8th, 2018, 16:09   #8
Intech
Good point.
Good info, nice pics, thank you
Old March 9th, 2018, 07:09   #9
ToddA1
Fuel Economy: Dismal
I kept the reverse pigtail stock, but changed the reverse switch. I think it was a $2 part, for an A2. I’d rather not cut wiring, if not needed.
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is online now   Reply With Quote
Transmission/Shifter question starrd VW MKIII-A3/B4 TDIs 6 August 29th, 2013 19:52
Shifter question bgsnyder TDI 101 0 July 29th, 2011 05:26
Shifter Question? Savageman69 Ontario 12 April 16th, 2008 04:45
Automatic shifter question k45 TDI 101 1 August 20th, 2007 14:24
Short Shifter Question wiezzl TDI 101 13 September 27th, 2003 03:16
Page generated in 0.14914 seconds with 10 queries
[Output: 96.77 Kb. compressed to 83.11 Kb. by saving 13.66 Kb. (14.11%)]
