Old March 6th, 2018, 17:39   #1
Cottickc
Default 2004 2.0 liter BHW swap into 1994 Toyota
Iím new here and have done a fair bit of research, but with so much knowledge on this site I figured I would look for assistance. I got the BHW out of the donor 2004 Passat, I have the entire wire harness that was in the engine bay(unplugged it from the ECU and electrical block under it). I am swapping into a 1994 Toyota 4X4 pickup with a manual transmission Here are my questions:
1). What do I need from the inside wire harness besides the accelerator pedal and scanner plug?
2). Thoughts on swapping to the old style oil pump from the balance shaft model I currently have?
3). Thoughts on the EGR delete?
4). Was going to send the ECU to Malone tuning to have the immobilization removed and a stage 2 tune, anything else I need done to get it to run?
Iím good on all the mechanical and fabrication work, itís the electrical portion I could really use some advice.
Cottickc is offline   Reply With Quote
Old March 7th, 2018, 00:57   #2
jimbote
jimbote's Avatar
grab the entire harness, relay, and fuse box, your life will be much easier with all the bits... affirmative on the bsm delete, my bhw/alh hybrid is deleted, zero issues over 125k miles
jimbote is online now   Reply With Quote
Old March 7th, 2018, 03:29   #3
PickleRick
PickleRick's Avatar
I've noticed the egr issues on the BHW are not nearly as common as other vw diesels. I'd consider Michigan near the artic circle(compared to my local). Would tossing the egr on that conversion lead to a longer engine warm up time/colder cab heat longer for minimal power gain?
Also, are the stock Toyota flywheels heavy enough on this conversion or should the swaps use the near 40lbs centerforce clutch/flyweel combo that was developed for the off road yota guys with dual transfercase set ups looking to pop the clutch without a stall while climbing rocks?
Weddings are basically funerals with cake
PickleRick is online now   Reply With Quote
Old March 7th, 2018, 05:27   #4
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
Affirmative on the above - go with the Delete - 200k km on mine (ALH pump, BRM gears) with no issues.
I also would not worry about the EGR on this engine, they cause few if any problems, unlike earlier cars. I had mine out to check and it had minimal carbon around it.
Malone did the auto-manual stage2 tune on mine, no issues there either.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old March 7th, 2018, 16:06   #5
Cottickc
Any specific oil pump kits that you recommend? Does anyone sell a specific wire harness for these swaps? Does anyone recommend a specific adapter kit? I was looking at the Acme kits. Thanks
Old March 7th, 2018, 17:21   #6
PickleRick
PickleRick's Avatar
I've heard too many issues with the acme kits being off center. This has led to input shaft bearings going out and other transmissions damage. Gastodiesel sells kits for a few hundred more that will both fit better and are more compete. He's also a vendor on here.
You'll have to make your own harness. I'm having a malone tune done on both my BHW projects by another vendor here who does the malone tune in the states. Malone should be able to provide diagrams on the BHW for you, if not others should be able to help. I'll be getting some in a few weeks and the moment i do I'll gladly share the wealth.
You'll want to remove the harness from your donor car. Don't give into the urge to cut anything! It's supposed to be simple from what ive been told. Ive yet to pull mine. Between work and my 5 speed 05 tdi passat conversion I've been too busy. Once my driver passat is ready to go the work begins on putting the 2.0 motor in my boat.
Old March 7th, 2018, 17:35   #7
TDIMeister
Phd of TDIClub Enthusiast
Moderator at Large
TDIMeister's Avatar
TDI(s): TDI
Member Hasenwerk can also do a custom tie-in of the BHW ECU and harness to talk to the rest of the vehicle, plus the necessary programming for a manual transmission on said ECU, immo-delete and gauge cluster-ignore.
Brake and clutch pedal switches should probably also be added.
How are people doing VSS?
Old March 7th, 2018, 18:36   #8
PickleRick
PickleRick's Avatar
If I remember correctly its just like the land cruiser and run off of the transfer case. You probably are not asking in reference to the speedo....i should on bed
Old March 8th, 2018, 05:23   #9
Windex
Windex's Avatar
I went with this one: https://www.idparts.com/balance-shaf...hw-p-3161.html
As it came with everything ready to go. Other vendors also sell a similar kit.
Old March 8th, 2018, 10:42   #10
Cottickc
Ok, thanks for all the support. I will say... getting the complete harness out of the donor Passat on the inside of the car is challenging... that thing is burried like a tick on a coon hounds hind end. But, I didnít cut any wires and got it out. Take your time! Itís a massive bundle of wires! Now I get to work backwards from the engine to figure out what stays.
2001 allroad BHW Swap from 2004 Passat arjax TDI Conversions 3 November 14th, 2017 19:21
1994 Toyota TDI conversion FredS TDI Conversions 99 January 10th, 2016 10:08
1994 Toyota 4x4 (ALH TDI conversion) FredS TDI Cars for Sale/Wanted 15 August 1st, 2015 12:07
FS: 2004 BHW complete swap (Nor-Cal) xsp2467 Private TDI Items for Sale/Wanted 6 June 11th, 2014 14:08
1994 toyota pickup TDI TDI-yota TDI Cars for Sale/Wanted 1 December 16th, 2012 10:06
Page generated in 0.14684 seconds with 10 queries
[Output: 99.48 Kb. compressed to 84.60 Kb. by saving 14.88 Kb. (14.96%)]
