Old March 6th, 2018, 16:54   #1
Ls3ase
Default N75 / N18 help
I have a 1z / ahu swapped in a toyota
I swapped the n18 valve in for the n75 because I need vacuum to pull the turbo wastegate open.
If I simulated 10-30 lbs of boost to the ecu my n75 / boost valve duty cycle does not change nor does the wastegate move
Did I make a wiring mistake?
How to I get the n18 to open the wastegate?
How many pounds of boost does the ecu need to read before it opens the wastegate?
Ls3ase is offline   Reply With Quote
Old March 6th, 2018, 20:23   #2
KLXD
If you really have bacuum plumbed to actuate the wastegate on a stock 1Z/AHU that's your problem.
Wastegate is operated by manifold pressure on these.
If you have something other than a stock TC installed you should say so.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old March 6th, 2018, 23:52   #3
Ls3ase
Winner winner.. it’s a vacuum operated actuator on an aftermarket turbo
Old March 6th, 2018, 23:53   #4
Ls3ase
I thought I was clear, sorry.
I swapped the n18 valve in for the n75 because I need vacuum to pull the turbo wastegate open ON A AFTERMARKET TURBO.
Old March 7th, 2018, 02:14   #5
jimbote
jimbote's Avatar
did you have the ecm tuned for a vnt and n75 ?
Old March 7th, 2018, 06:27   #6
Ls3ase
No, this is not a vnt turbo.
Old March 7th, 2018, 07:53   #7
KLXD
Well that's very different.
I may be showing my ignernce here but that's ok if I've got it wrong I learn something.
With a stock AHU when you have too much willy the ECU applies some manifold pressure to open the wastegate.
With your system you want it to apply some vacuum.
Seems to me the basic ECU logic would be the same.
So...Do you have it plumbed right? Common port to the actuator, NO port to the airbox and NC to the vacuum source?
Old March 7th, 2018, 11:49   #8
jimbote
jimbote's Avatar
you're probably going to need some custom chips to run that style setup... seems the ahu/1z pressure dependent n75/wastegate setup should only open when the max boost set point is achieved which means it'll be closed until that point is reached, you need it to be open and transmitting vacuum to close the actuator until boost setpoint is achieved, so it's working backward to what you need ...someone please chime in if i'm wrong
Old March 7th, 2018, 12:15   #9
Ls3ase
It works the same way as the stock turbo except with vacuum
Old March 7th, 2018, 13:08   #10
jimbote
jimbote's Avatar
If it's a vacuum actuated wastegate then it has to have vacuum applied to close the wastegate and make boost... a pressure actuated wastegate applies pressure to open the wastegate and reduce boost ... from the quick reading I did the vacuum actuated wastegate does not have a spring to keep the wastegate closed but relies purely on vacuum... Is this not the case with your turbo?
Old March 7th, 2018, 14:20   #11
KLXD
Well that's very different too. I assumed vacuum was used to open it.
I'll shut up and listen now.
Old March 7th, 2018, 15:03   #12
Ls3ase
Vacuum opens this wastegated and reduces boost
Old March 7th, 2018, 15:30   #13
Ls3ase
Someone with a tdi b4 Passat will you...
Post a screen shot of 002 and 006 measuring blocks in vcds?
Post a screen shot of 011 measuring block when supplying the Ecu with 20lbs pressure w/ a mighty vac or something similar
Measure the turbo actuator pressure when supplying the Ecu with 20lbs of pressure w/ a might vac
Measure the voltage at N75 at 1lb and 20lbs pressure to the Ecu
Pretty please?
Old March 8th, 2018, 12:37   #14
Hasenwerk
Hasenwerk's Avatar
Pretty please?
I really don't think you understand how your turbo / N75 valve works.
Your wastegate opens when only pressure is applied to it. The N75 valve's job is to block pressure flowing to the wastegate until the ECU turns on the N75 valve. Vacuum has nothing to do with opening your wastegate. There is always manifold pressure going to the N75 valve and when the ECU wants to open the wastegate, it applies a ground to the N75 valves (there is always 12V going to it) allowing that pressure to pass and actually push on the wastegate and opening it. The ECU controls the wastegate with pulse width modulation, not a varying voltage, as it is either "on" or "off". So measuring voltage would give meaningless results as it is always 12V on one side of it and the other side is ground/float state. VCDS will show you the duty cycle of the N75 valve and my experience is that VCDS vs what is the actual duty cycle is the same.
David Marshall
Fast Forward Automotive
TDI Stand Alone Wire Harness Manufacturing | Signal Converters, Gateways, and Processors | Vehicle Speed Sensors | Malone Tuning
Hasenwerk is offline   Reply With Quote
Old March 8th, 2018, 15:40   #15
Ls3ase
Please tell me what turbo I am running?
Please tell me what happens to MY actuator when vacuum is applied?
Please tell me what happens to my n75 and n18 valves when I use vacuum instead of pressure?
Please tell me you have actually measured 12v at the N75
I've actually tested with vacuum, pressure, and gauges...
David please stop replying to all of my posts anywhere. Your posts are useless.
n18 and n75 02VWTDI TDI Power Enhancements 1 September 5th, 2012 15:29
N75 exactly the same as N18 ? MethylEster TDI 101 2 August 16th, 2012 07:58
Anyone have an N18 or N75? chaloux Ontario 5 March 22nd, 2011 00:14
N18 and N75 geez VW MKIII-A3/B4 TDIs 2 June 13th, 2010 22:20
N18 vs N75 TDITN TDI 101 1 May 2nd, 2005 12:43
Page generated in 0.16601 seconds with 10 queries
[Output: 125.74 Kb. compressed to 104.44 Kb. by saving 21.29 Kb. (16.94%)]
