Old March 6th, 2018, 14:07   #1
JG321PM
TDI(s): 2014 Q7 TDI
Default 3.0 2014 Q7 "Fixed Issues"
2014Q7 TDI is having a lurching issue which only started after the "Fix"!
Anyone else having this issue?
Dealer is telling after two weeks with the car $700 to drain the tank and place a new fuel filter. Then they would test to see if that is the issue.
Note: They had the vehicle 3 days and couldn't get it to replicate the lurching. I go back for 15 minutes and it does it.
Any advice or ideas? Tired of being played.
JG321PM is offline   Reply With Quote
Old March 6th, 2018, 16:36   #2
flargabarg
Do a throttle and transmission adaption reset. Turn on the car but do not start it. Then hold the accelerator pedal down for thirty seconds. Release the pedal. Turn the car back off. Next time you start it, it should start to learn. The reason they say it is okay and you are having trouble is because they have a different driving style, and the transmission programming changed with the fix. This has also been in a couple of other threads here.
flargabarg is online now   Reply With Quote
Old March 6th, 2018, 16:39   #3
flargabarg
http://forums.tdiclub.com/showpost.p...&postcount=254
Here is a post about it.
Old March 6th, 2018, 16:48   #4
JG321PM
TDI(s): 2014 Q7 TDI
I had read about the throttle reset and asked them to do that. The dealer swore it wouldn't work on the diesel according to the Audi USA technical advisor.
I appreciate it. I am at this point I may go up there and do that to see if it works.
Old March 6th, 2018, 17:09   #5
flargabarg
It has worked on other Volkswagen automatics for me in the past. Hopefully it will help you. It's very easy to do, so worth the try.
Old March 6th, 2018, 19:03   #6
Mythdoc
Mythdoc's Avatar
Your dealer probably thought you were referring to a software throttle reset, which, indeed, does not work on a diesel. Do the procedure flargabarg describes above and report back.
“Yeah, well, y’know, that’s just like, uh... your OPINION, man.” —The Dude
2015 Q5 TDI w/ Chipwerke tuner, 30K Miles
2011 Touareg TDI 74K Miles (sold back to VW, May, 2018)
2015 Golf TDI 22K Miles (son’s)
Mythdoc is offline   Reply With Quote
Old March 10th, 2018, 20:23   #7
JG321PM
TDI(s): 2014 Q7 TDI
Default Update
Doing the throttle reset didn't work. Dealer is adamant it is the fuel. Will post back an update later.
Old March 11th, 2018, 07:38   #8
Mythdoc
Mythdoc's Avatar
Fuel filter can be replaced without draining the tank. Check with an independent garage. $700 seems outrageous. Also after replacement I’d run a bunch of diesel fuel additive through to isolate H20.
Old March 19th, 2018, 21:35   #9
dyehead
My Q7 is back at Audi for the NOX system again. They had to order parts from Germany last time.
Glanced over the shoulder of the tech who checked the codes and there were 3 errors. One said something about “performance regulator” or something. Incredibly fishy. They made up some excuse saying it was linked to the NOX system and quickly cleared all the alerts.
From a non mechanic it sure looked like something to do with why the car feels sluggish by the description.
The only thing that makes me think it’s innocuous is that I figure someone would have blown the whistle on something like that but even so, super suspicious.
dyehead is offline   Reply With Quote
Coolant leak fixed - big thanks to Brian "oilhammer" Mad_Max VW MKV-A5 Golf/Jettas 5 September 3rd, 2013 18:11
Has anyone "fixed" the RNS-510 to be able to view DVDs while in motion? TDI_Ryan VW Passat Family (NMS and B7) TDIs (2012+) 25 April 3rd, 2013 16:22
"Fixed" the glow plug CEL problem but still starts rough andrewb_1985 VW MKIV-A4 TDIs (VE and PD) 2 November 6th, 2008 07:07
2002 Golf hatch lock problem fixed "how To" CaTdi2002 TDI 101 3 September 12th, 2008 16:08
"Mileage" vs. "MPG" vs. "Mile range" vs. "Miles per tank" boyelectric TDI Fuel Economy 33 August 19th, 2002 06:06
Page generated in 0.14770 seconds with 10 queries
[Output: 89.44 Kb. compressed to 76.63 Kb. by saving 12.81 Kb. (14.32%)]
