Old March 6th, 2018, 10:04   #1
prsa01
Default Rediculously slow pump?
Up here in the northland (MN), my last 2 fills have been at unfamiliar stations on road trips. Both times the pump was crazy slow. Took better part of 10 minutes to fill. Heard someone else saying the filter must be mostly clogged.
Wondering if this is most likely a filter issue or something else and if so if I'm running dirty fuel and should plan on changing my filter after this tank.
Only running the stock filter on my b5. Hoping I'm not destroying my injectors.
Thanks for any input
'06 BRM Jetta; 5spd - ziptie mod
96 B4v
eCodes
prsa01 is offline   Reply With Quote
Old March 6th, 2018, 10:22   #2
compu_85
Gadget Guy
compu_85's Avatar
Yes, it's likely the pump's filter is either clogged, or the fuel isn't treated properly. When I encounter a slow pump I move on.
-J
Present:
2013 Fiat 500e. 22,000 miles.
Past:
Old March 8th, 2018, 07:12   #3
The Tortoise
I've only encountered slow pumps in temperatures below -20C. Both times towards the end of the fill-up it started to flow at the regular rate. I just assumed the cold temps made it harder to pump the diesel.
The Tortoise is offline   Reply With Quote
Old March 8th, 2018, 07:46   #4
Rodmiser
Fuel Economy: 47 MPG last 10 tanks & 57 MPG BEST
Default filter
Yes here in Kansas City MO, at Costco will time the diesel pump just to see if it needs a new filter. Yes COLD weather to.
Rodmiser is offline   Reply With Quote
Slow Death of a Vacuum Pump Aridzonan TDI 101 0 September 24th, 2012 13:06
Running slow after oil pump tensioner/intake cleaning job Texas_sky VW MKIV-A4 TDIs (VE and PD) 2 February 29th, 2012 23:14
REDICULOUSLY LOW Trade -IN rolling18 VW MKV-A5 Golf/Jettas 105 February 21st, 2009 17:02
Slow fuel pump = old filter? VT-TDI Fuels & Lubricants 0 July 25th, 2008 07:21
slow fuel pump VDubbing Fuels & Lubricants 3 July 17th, 2006 19:12
Page generated in 0.12376 seconds with 10 queries
[Output: 64.47 Kb. compressed to 57.86 Kb. by saving 6.61 Kb. (10.25%)]
