Old March 6th, 2018, 10:48   #1
Jtlawrence28
Angry Car starts then dies a few seconds later
Hello,
I need some help please. The other day I accidentally arced a ratchet extension against the alternator while I was changing the thermostat. Once I got finished replacing the thermostat I drove the car for about an hour then left it running for about another hour after that. The next day I started it and it died about 2 minutes later, and every time after that I start it and it dies a few seconds later. I light tested all of the fuses, and they are working. Everything else in the car seems normal.
I would appreciate any help I can get. I am really hoping I didn't screw up anything too serious.
Jtlawrence28 is offline   Reply With Quote
Old March 6th, 2018, 11:56   #2
Mike_04GolfTDI
Mike_04GolfTDI's Avatar
Is there a little key symbol on the instrument cluster when you start the car?
If so, that would mean the immobilizer doesn't recognize the transponder chip in the key fob. When that happens, the car will start, and then stop a couple seconds later.
Looks like this:
2004 Golf GLS TDI 5-spd, DC Stage 1 Clutch, Evolution Atlas Skid Plate, Malone Stage 4 Tune, GT1749VB Turbo, 3 bar MAP
Mike_04GolfTDI is offline   Reply With Quote
Old March 6th, 2018, 12:07   #3
Jtlawrence28
No, that icon does not show up. I did forget to mention in the original message that the oil light comes on (blinking) and there is a beeping that comes with it.
I appreciate the response and any other help you can give me.
Old March 6th, 2018, 12:21   #4
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
An oil light after extended cranking is normal, if you get it with the motor running, different issue.
Old March 6th, 2018, 15:09   #5
Vince Waldon
Vince Waldon's Avatar
The line you shorted is protected by a big fuse on top of the battery box... was that one of the fuses you checked?
Failing that, measuring voltage at the battery post would be a good diagnostic... if the charging system was damaged the battery is probably discharged.
Vince Waldon Edmonton AB Canada
Note: The above is to the best of my knowledge- but at the end of the day simply interweb opinion, worth EXACTLY what you paid for it, and if used done so at your own risk.
Vince Waldon is offline   Reply With Quote
Old March 6th, 2018, 17:39   #6
Mongler98
REMOVE - TERMINAL from battery
this is literally a VW Meme
its seriously a big issue you must do when changing your wiper blades and dont even think about washing her with out removing the battery and covering all your electronic connections with ziplock freezer bags with zipties.
Old March 6th, 2018, 17:43   #7
Jtlawrence28
I learned that the hard way. I hope I didn't screw the car up too bad
brm starts and dies in 2 seconds rfaass VW MKV-A5 Golf/Jettas 9 January 16th, 2015 11:08
Car starts but dies 2 seconds after. el fuego VW MKIV-A4 TDIs (VE and PD) 5 September 2nd, 2011 07:05
car starts then dies 2 seconds later plomagli TDI 101 10 September 19th, 2009 17:38
Car starts for 2 seconds then dies vwjettadsl TDI 101 28 July 16th, 2009 19:44
Engine Starts, but Dies in 2 seconds neildeshpande TDI 101 17 September 2nd, 2007 00:20
Page generated in 0.14481 seconds with 10 queries
[Output: 79.11 Kb. compressed to 68.71 Kb. by saving 10.40 Kb. (13.15%)]
