Old March 6th, 2018, 07:45   #1
charlieruu
Fuel Economy: who cares
Default What shape g68 sensor do I get?
I have an 02 alh auto with an 01m transmission. My car threw a P0722 and I started to look into a new speed sensor. On ID Parts they have a D shaped sensor and a square shaped sensor. I'm having trouble finding out what sensor I should be getting. If anyone could help me figure out which one I need that would be awesome. Thanks!
charlieruu is offline   Reply With Quote
Old March 6th, 2018, 08:05   #2
JETaah
Fuel Economy: 53 max, 42 min, average 46
It is probably referring to the shape of the harness connector. Call them up and ask. Maybe it changed shape after a certain model year. That may not be totally reliable since many of these transmissions have been swapped out, rebuilt, or otherwise and the harness connector could have been changed to match the sensor on the trans.
Follow the sensor's wire back to the harness.
"D" shape has one rounded end.
Both are pictured on IDparts website.
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Old March 6th, 2018, 08:44   #3
Rob Mayercik
Yeah, there was a split around 2002 between a square and a D connector for those.
Best bet is to call and have them help you figure out which one you need.
2002 Jetta GLS TDI Automatic
Baltic Green/Beige Leather
Rob Mayercik is offline   Reply With Quote
Old March 6th, 2018, 09:35   #4
JETaah
BTW... that sensor is under the bracket where the transmission mounts to the chassis mount. It is not terribly visible unless you move the bracket and you would need to support the transmission to do that. But, there would be only one wire (cable) coming from under there so following it to the place where it terminates next to the gear shift cable should not be too hard.
Again, look at the IDparts picture to see what you are looking for.
Old March 7th, 2018, 12:20   #5
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Only real early cars like 99 and earlier had the "square" connector. (and eurovans)
see the link here
http://kansascitytdi.com/shopping/
But if my memory serves me correctly your checking into the wrong sensor. P0722 refers to the output speed sensor or G68. The "square" vs "D: shaped connector only applies to the G38 "sun gear shell speed sensor" (commonly called "input speed sensor"), which would trigger P0715. You need to look into the G68 sensor. See link posted above.
Also for sensor position see the link below in the section titled 01m sensor locations
http://kansascitytdi.com/o1m-faq/
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Fixed 00281 code with a new G68 sensor. TDIntercool VW MKIV-A4 TDIs (VE and PD) 2 October 25th, 2014 17:22
01M g68 speed sensor 01VDUBTDI Private TDI Items for Sale/Wanted 0 April 1st, 2014 07:33
G68 sensor removal Timbo1080 TDI 101 13 February 21st, 2014 15:32
How do I change the G68 Sensor cable? gebbeth VW MKIV-A4 TDIs (VE and PD) 7 July 30th, 2013 20:08
00281 - Vehicle Speed Sensor (G68) looking4tdi VW MKIV-A4 TDIs (VE and PD) 2 May 1st, 2005 13:15
Page generated in 0.11229 seconds with 10 queries
[Output: 70.28 Kb. compressed to 62.12 Kb. by saving 8.16 Kb. (11.61%)]
