Old March 6th, 2018, 06:09   #1
STOKTDI
Default Body Roll Solution
Okay so I am tired of body roll in the golf. My mk4 was awful and the mk7 experiences some as well (just enough to feel). My buddy/roommate simply added a rear brace to his civic SI trunk and the entire car firmed up.
LINK: https://www.urotuning.com/UNIbrace-X...ibrace-xbq.htm
This is just one of the options for interior bracing (yes i know there are simpler tubular versions). Would this firm the car up as much as a rear sway bar such as http://www.urotuning.com/Neuspeed-Re...25.02.22.2.htm.
I plan on doing the VWR lowering springs so I am simply worried about beating up the rear "torsion" bar due to crappy Ohio roads. I have read reviews/threads on the torsion bar but I have wondered if the interior brace would help with roll at all?
STOKTDI is offline   Reply With Quote
Old March 6th, 2018, 07:13   #2
A rear shock brace and anti roll bar do entirely different things. The MQB platform is pretty stiff, I doubt you'd see much change with a brace.
I'd suggest a rear bar, one that fits inside the rear beam. Don't now if anyone makes it, we may at some point. These make a world of difference in this suspension design. I've had one in my MKIV Wagon forever and still love it. However, keep in mind it can cause the car to be a little tail-happy in slick conditions.
Old March 6th, 2018, 08:45   #3
STOKTDI
I figured the brace wouldn't do much. What does the one on your MKIV look like? I am pretty creative and have some resources. I might try to make something myself it is worth it.
Are there any other mods besides the typical front sway bar for the MKVII golfs to make them handle better?
Old March 6th, 2018, 09:05   #4
IMO a front sway bar doesn't help. Just increases already present understeer.
Rear bar looks like this: https://www.idparts.com/mkiv-rear-sway-bar-p-1372.html
Another option is better dampers. Koni Yellows would help, and they also are adjustable so you can find tune the handling the way you want.
Old March 6th, 2018, 09:11   #5
STOKTDI
Does that simply bolt right to the rear bar?
Are better dampers recommended with the VWR springs? Reviews on those range from they have lasted years to they ruined stock dampers within a month. I am trying to hold out for Raceland to make a bag kit for the MKVII golf tdi platform so for now I just want to improve handling.
Old March 6th, 2018, 10:54   #6
Install requires drilling the rear beam and bolting the bar inside the beam.
I would definitely upgrade dampers with R springs. The stock Golf dampers aren't valved for the shorter travel.
Old March 6th, 2018, 13:07   #7
VWjunkie
TDI(s): 15 GSW SEL
I put on lower springs and added the NEUSPEED rear torsion bar and the body roll has toned down a lot. It was definitely worth it, in my opinion.
VWjunkie is offline   Reply With Quote
Old March 6th, 2018, 13:51   #8
STOKTDI
Do you have a pic of ground clearance for NEUSPEED torsion bar? Assuming springs are 1" lower?
Old March 6th, 2018, 13:52   #9
STOKTDI
Easy enough to install. Any thought on MKVII platform or no?
Really wanted to hold out for bags but I might as well just buy an all in one coilover set at this point.
Old March 8th, 2018, 15:35   #10
Curious Chris
Fuel Economy: 47/42/38
I went up one up on all the coil springs and Koni Yellows. I have not body roll.
Curious Chris is offline   Reply With Quote
bad body roll volks27 VW MKVI-A6 Golf family including Jetta SportWagen (~ 2010-2014) 7 August 17th, 2016 05:06
Excessive body roll... Kingcodez TDI 101 12 October 21st, 2012 13:48
Looking To Reduce Body Roll grcarlo Upgrades (non TDI Engine related) 1 March 10th, 2010 18:40
Why the A4 body roll ? Daan VW MKIV-A4 TDIs (VE and PD) 29 November 7th, 2004 16:02
reduce body roll? rynmls Upgrades (non TDI Engine related) 4 May 23rd, 2002 14:11
Page generated in 0.17615 seconds with 10 queries
[Output: 96.35 Kb. compressed to 82.34 Kb. by saving 14.01 Kb. (14.54%)]
