Old March 5th, 2018, 16:55   #1
Tigger Welder
Default No Start/dies
My 2003 Auto TDI is in need. I was driving to work the other day and the car just cut off, rolled to a stop. It would turn over, but wouldn't fire. Ultimately had to tow it home. I charged the battery and put the electric pump on it to see if it had lost prime. Got it to start, let it run for a while, and took it for a test drive. It drove fine down the hill past my house, but died when I started to go up the hill. At that point it would only click when I tried to start it. Charged the battery overnight, and still nothing, had it tested, bad cell, bought a new battery. Even with the new battery and jumper cables, nothing but clicks. Any ideas?
Tigger Welder is offline   Reply With Quote
Old March 5th, 2018, 18:49   #2
whitedog
Sounds like a bad connection from the battery to the starter most likely.
Old March 6th, 2018, 05:38   #3
jettawreck
jettawreck's Avatar
Does sound most likely andhopefully.
If a manual, you can jack up one front wheel and while in a gear see if engine will turn over w/o forcing it too much. If it resists, check TB condition and tension. Perhaps it has had an "event".
2004 Cadillac SLS (wife's)
Old March 8th, 2018, 09:44   #4
Tigger Welder
It is Automatic. The cable from the battery to the starter looks good, but I will inspect it more closely. The timing belt was fine when it first died, verified it was on and turning when I was bringing it home from its first incident. since it won't turn over, so I haven't checked. There is a different sound from doesn't try to won't turn, and this is definitely doesn't try. More tonight.
Old March 8th, 2018, 09:47   #5
Tigger Welder
Well damn! Just checked and the belt is shredded! Anybody want to buy a brand new battery? ARGH!
Old March 8th, 2018, 11:28   #6
roni024
I had a timing belt go on my old 1998 Jetta TDI. I had the head rebuilt by a local machine shop and did the R&R myself. I think it came in at under $1000 all in. I've also heard good things about Franko6's heads (look him up here on the club).
The original cause of the belt failure was cheap eBay parts sold by a well-known (and well-hated) eBay parts seller.
Good luck, whichever way you decide to go.
roni024 is offline   Reply With Quote
Start and then dies perrya VW MKIV-A4 TDIs (VE and PD) 3 February 4th, 2016 13:39
car randomly dies then no start TDIGuy2011 VW MKIII-A3/B4 TDIs 49 August 8th, 2013 13:02
dies on start up l1o9s7t6 VW MKIV-A4 TDIs (VE and PD) 2 October 28th, 2005 11:11
dies on start rifaco TDI 101 4 January 17th, 2004 18:41
Help will not start, fires tries to run, then dies, will not start after that The Ripster VW MKIV-A4 TDIs (VE and PD) 8 May 31st, 2001 20:30
Page generated in 0.15237 seconds with 10 queries
[Output: 73.56 Kb. compressed to 64.52 Kb. by saving 9.04 Kb. (12.29%)]
