Old March 5th, 2018, 16:46   #1
Default mk7 hub install help
I'm putting lift spring on my Mk7 sportwagen and the fronts are really fighting me. I'm battling my way through and starting to loose my mojo.
Can someone please give me some "tips" on how to ease the installation of the hubs. The axle spline doesn't want to line up and slide on.
hause is online now   Reply With Quote
Old March 9th, 2018, 08:57   #2
Powder Hound
Powder Hound's Avatar
Got any photos of where it is hanging up? It is hard to offer advice without having a look-see, so take this for as much as you are paying for it:
I will assume* that the strut and control arm are bolted to the bearing carrier assembly and the hub is properly pressed into the bearing. I will also assume* that the suspension is very similar to the mk4 front end, since I've not looked over your generation of front end. Seems to me that a simple rotation of the hub will resolve any meshing problems, so the problem is probably contained in the lift portion of the project. That is, the hub is now lower in relation to the half-shaft, so the axle stub would be coming into the hub at a bad angle. Maybe you can ameliorate the situation by putting a jack under the hub to lift it up some.
Hope this helps, but since I'm lacking in experience with a mk7 front end, you may feel I'm an idiot by now. Sorry if that is the case, but my intentions are good.
* - of course everyone knows what happens when you ass-u-me, right?
Polo 6n stub axle/ 9n hub / hub upgrade to b4 ninedee_golf_tdi VW MKIII-A3/B4 TDIs 9 January 25th, 2017 21:38
LRR Tires 4x100 to 5x100 hub kit? install honda insight 165/65/r14 rims/tires on mk4 bobmutch TDI Fuel Economy 25 December 16th, 2013 15:50
97 Passat rear rotor-hub install report Dean_S VW MKIII-A3/B4 TDIs 0 April 29th, 2003 08:24
Page generated in 0.13653 seconds with 10 queries
[Output: 51.70 Kb. compressed to 47.69 Kb. by saving 4.01 Kb. (7.75%)]
