Old March 5th, 2018, 11:15   #1
Greg1289
Default Need help please blue smoke
Ok where do i start I知 quite new to the forum so by saying hello all
And I知 not sure if I知 posting in the right place
Iv had my seat Leon mk2 fr 2.0 tdi bmn engine code for a few year now and been modifying as the year have gone by. So basically I知 running a 2260vk turbo with a few other bit n bobs. After fitting the turbo and finally getting the clutch right I was hoping to get the final map done my narrco when the car started smoking. When I mean smoking, blue smoke when the car got up to temp and a longish drive and say you stopped for fuel and come to restart the car it will fill the forecourt with blue smoke but would clear. If the Car is cold or even been standing the smoke is minaul normal start up smoke. Anyway narrco sed they wouldnt map it until it痴 sorted. Cut a long story sort the engine was rebuilt and after running the engine in it seems like the problem is still there or come back
I知 just wondering or hoping someone if anyone has any ideas or even had this problem
Greg1289 is offline   Reply With Quote
Old March 5th, 2018, 12:48   #2
ToxicDoc
TDI(s): 2001 Jetta
Blue smoke is oil being burning. Is this a new or used turbo? Check your oil level. Pull the hose at the intercooler and check for oil there. When the engine was rebuilt, what was done to the heads? Were valve guides changed?
ToxicDoc is offline   Reply With Quote
Old March 5th, 2018, 13:35   #3
Greg1289
Everything is brand new inside the engine apart from pistons. Iv had a recon head as the last one had cracks with new valve stem seals when they fitted the uprated valve springs. The reason I rebuilt the engine was when I removed the turbo there was oil on top of the exhaust valve on cylinder two. Which was tell me valve stem seal. Il do the checks you mentioned tomorrow
Old March 6th, 2018, 13:44   #4
adamss24
Fuel Economy: 35-45mpg
Who done The turbo ? I have seen a few rebuilt gtb2260vk turbos that we’re smoking blue due to poorly routed turbo oil drain pipes or misadjusted vnt levers...narco is doing well not to tune your motor - it could blow on the rollers !
adamss24 is offline   Reply With Quote
Old March 7th, 2018, 08:30   #5
[486]
TDI(s): 02 golf ALH
Measured piston/wall clearances and ring end gaps?
It's still likely the head from your description of mainly smoking on a hot start
easy enough to cut a stem seal while installing
[486] is offline   Reply With Quote
oh no blue smoke!!! help please johnjames1234 TDI 101 13 February 3rd, 2010 14:02
Blue Smoke Farfromovin TDI Power Enhancements 290 November 21st, 2008 16:09
Blue Smoke eyetdiman VW B5 Passat TDIs 6 April 24th, 2007 04:35
Blue Smoke, No Smoke, & Vacuum crvsecretary VW MKIII-A3/B4 TDIs 0 November 29th, 2006 08:19
Black sooty smoke then blue smoke... fo fo weed VW MKIV-A4 TDIs (VE and PD) 9 February 26th, 2002 17:34
ゥ 1996 - 2017, All Rights Reserved
Page generated in 0.14208 seconds with 10 queries
[Output: 68.62 Kb. compressed to 60.95 Kb. by saving 7.67 Kb. (11.18%)]
