Old March 5th, 2018, 12:03   #1
vwdsmguy
Fuel Economy: 49/46/42
Default exhaust heat shields
I have to keep rescrewing the shields to the body as the original anchors rust off. Other than over the cat, are the other shields really needed? I am sick of the rattles from these shields.
'02 Golf TDI, RC5, PP764's, FMIC, 2.5" T-Back, OMI, SB-3 clutch, 11mm pump, VNT17/22, 3 Bar MAP, CAT filter, 90 GPH Holley lift pump, modded D24 intake manifold, Rosten rods, Nural pistons, ported head - 15.0 @ 94 at the drags
vwdsmguy is offline   Reply With Quote
Old March 5th, 2018, 19:55   #2
ketchupshirt88
Fuel Economy: 40-42 with a lead foot.
Probably doesn’t belong in the “power enhancement” section but...
Yes you can remove the rattling aluminum heat shields. If you are concerned about certain areas such as above the cat, you can use that foil backed insulation like on your firewall
that stuff won’t rattle and is dirt cheap or even free from junkyards.
2003 Jetta TDI - 11mm IP, R520s and FMIC from the Red Death, HE221W (shooting for 26PSI), 1.8T pancake, DIY 3" OMI, still working on the DIY tune... its a learning process.
1996 Passat TDI - "Red Death" RETIRED. Had: Malone stg 1, 11mm IP, R520s, GT15/17 hybrid, FMIC, ETC
1997 Passat TDI wagon - Running donor or beater for sale, rough body
ketchupshirt88 is offline   Reply With Quote
Old March 5th, 2018, 20:46   #3
Fix_Until_Broke
Fix_Until_Broke's Avatar
Fuel Economy: 75.0/53.0/38.4
Remove them and don't worry about it. Mine finally fell off a couple years ago and no issues. I run sustained 1400+ EGT's with a trailer and an 8" outside diameter muffler where the cat used to be so it's close to the floor - no problems.
03 Jetta, Cat 2u, DG Steel SP w/MOGolf Mod, 3"DP, 4"EXH, EaBP100 Bypass, Euroswitch, ECodes, Driving Light, PD Lift Pump, R520's, RC5,RC6, TDTuning, Malone, ScanGaugeII, 3" TIP, 2" TOP, HE221W Compounded with GTC1444VZ, 6 Bar MAP, VR6 MAF, Vented Fender Liner, Battery Cover Mod, 11mm, Monster Mats, 215/55/17 (27.9/53.0/75) Monthly MPG Links, Euro Trunk Latch, IDParts RSB, SDI or ALH Intake, ARL Ceramic Pistons, Rosten Rods, DRW, Wavetrac, SBC, FSD's, Beef Springs, Rebuilt Head, Recaro's, Colt II, DG Sigma 6, RMT200
Fix_Until_Broke is online now   Reply With Quote
Old March 6th, 2018, 17:53   #4
Mongler98
remove that POS
Clean floor pan VERY CLEAN,
install this, it does an epic job and never comes off if put on a clean surface, and i mean CLEAN
I have my red hot GT2052 right next to my firwall and this keeps it from roasting stuff
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
How important are heat shields? vdubwannab TDI 101 8 June 30th, 2015 20:08
nozzle heat shields TDIPWR33 VW MKIII-A3/B4 TDIs 11 July 11th, 2014 10:04
Necessary heat shields jmcfarland56 TDI 101 1 July 31st, 2009 13:32
WTB: ALH Heat Shields for Exhaust Manifold FrankGRUN Private TDI Items for Sale/Wanted 2 November 30th, 2004 11:12
injector heat shields vwchris VW MKIV-A4 TDIs (VE and PD) 5 August 21st, 2000 15:09
Page generated in 0.13585 seconds with 10 queries
[Output: 65.70 Kb. compressed to 59.06 Kb. by saving 6.64 Kb. (10.10%)]
