Old March 4th, 2018, 23:23   #1
RedKaotik
Default VW Pin
Wow,
what a nightmare to acquire a simple 4 digit pin but now that I have it what can do with it?
I used it to program a second FOB that i found ziptied to the inside of my bumper(everyone should check,lol never know)
I also found out my mileage is off. Vag Commander says 225k. odometer says 140k hmmmmm.
RedKaotik is offline   Reply With Quote
Old March 5th, 2018, 05:49   #2
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
Easier to just blitz the immo completely and be done with that nonsense forever (unless you are actually concerned about vehicle theft, in that case, programming a key is probably the least of your worries).
Sounds like either your engine controller or your cluster has been replaced.
oilhammer
www.cardocautomotive.com
T28 and T28B Pin layout configuration !? color pin and slot? mazrik VW MKIII-A3/B4 TDIs 2 January 2nd, 2014 19:11
Coolant Level light flashes, which pin on 28 pin connector? 87homebuilttdi TDI Conversions 8 May 24th, 2012 04:29
WTT: PIE 8-pin Aux Adapter for 12-pin version. Redneck Truck Private TDI Items for Sale/Wanted 1 January 20th, 2010 07:01
2006 MAF low signal code no 12v pin 2 to pin 3 Prometheus VW MKV-A5 Golf/Jettas 0 July 7th, 2009 09:29
CD changer cable needed, 13 pin round to 10 pin sq chuckbrush Private TDI Items for Sale/Wanted 3 January 27th, 2005 21:44
Page generated in 0.11490 seconds with 10 queries
[Output: 52.31 Kb. compressed to 48.26 Kb. by saving 4.06 Kb. (7.75%)]
