Old March 5th, 2018, 10:11   #16
burn_your_money
Originally Posted by maxmoo View Post
I'm sorry but that's plain silly.
Do you put tires,brakes etc,etc on your vehicle occasionally?
The glow plugs are designed to help your tdi start not just to pass an emisions test....why wouldn't you want a functioning glow plug system?????
What I'm saying is an electrical harness shouldn't be a wear item. It's a poor design if it is. Also, why spend $100 when I can spend way under $20 and come up with a significantly better harness.
I buy core TDI pumps. PM me for details
burn_your_money is offline   Reply With Quote
Old March 5th, 2018, 11:56   #17
DavidMTroyer
TDI(s): 1999.5 Jetta
Fuel Economy: 39/43/49
You might get lucky applying some dielectric grease to the glow plugs where they interface with the harness. Even if it doesn't fix the problem, consider it with a new harness.
DavidMTroyer is offline   Reply With Quote
Old March 5th, 2018, 13:10   #18
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
I like the idea of rebuilding that GP harness. They sell the bits like the boots etc.
BobnOH is online now   Reply With Quote
Old March 5th, 2018, 13:20   #19
oilhammer
oilhammer's Avatar
Fuel Economy: fantastic
You can also have high resistance/poor connections through the glow plug relay. Or inside the relay itself.
You have to do a voltage drop test from inside the car to the plug connection on the engine, while some sort of load is placed on the system.
oilhammer
www.cardocautomotive.com
Old March 5th, 2018, 17:11   #20
burn_your_money
When you say plug connection do you mean the glow plug harness?
Old March 6th, 2018, 05:38   #21
oilhammer
oilhammer's Avatar
Yes, the four connectors made into the "bridge" otherwise known as a harness.
The glow system in these cars is brutally simple, not much to it. I have had DIYrs come in here having given up trying to fix them, only to find out their cheapo Chinavolt multimeter was unable to properly check the plugs. Have had that happen a couple times. My Fluke ET88 works fine. It also cost $400. 25 years ago. Used ones are still worth north of $150. You get what you pay for sometimes.
oilhammer
Old March 6th, 2018, 07:08   #22
paul_cat
2 cents of input - I used to have these codes each season-change, then I put some dielectric grease into each GP socket and they have been error free for several years now. Cheap insurance...
paul_cat is offline   Reply With Quote
Old March 6th, 2018, 12:59   #23
DavidMTroyer
Same.
Old March 6th, 2018, 17:25   #24
burn_your_money
My harness is past the point of grease. If I go with a factory one I'll definitely grease it.
Does anyone have a wiring diagram for the glow plug circuit? I'm having a hard time understanding how the ECM monitors the glow plugs if there is only 1 relay.
Old March 6th, 2018, 20:56   #25
wonneber
I'm still using my Fluke 77 vintage late 70's (iIrc)
Doesn't have the newer features and I could use a max/min & freeze.
Maybe scope in one also.
Old March 7th, 2018, 03:41   #26
jimbote
jimbote's Avatar
i've repaired several composite glow plug harnesses by breaking off the over molded rubber, tightening the female bullet connectors, reinserting them into the plastic sleeves, and heat shrinking the bare crimps... I squeeze a little bit of black silicone into the top end of the plastic sleeves around the wire to hold it in place
Old March 7th, 2018, 12:19   #27
burn_your_money
Well I made some time after work this morning and threaded the glowplug terminals and built a simple harness. I'm back to having 2 wires instead of just one feeding the glowplugs. I cleared the code and shall see how long this lasts. Considering how quick and easy it was I'm surprised that anyone bothers with the factory style harness.
I tested the glowplugs while they were out and they all started smoking almost immediately when put to power.
Regarding cheap testers, I used my cheap one at home and my not so cheap one at work. Both gave similar numbers so I don't think that is my issue.
Old March 7th, 2018, 22:46   #28
ToxicDoc
TDI(s): 2001 Jetta
Post a pic. Would like to see your setup
ToxicDoc is online now   Reply With Quote
Old March 8th, 2018, 13:14   #29
burn_your_money
I got my bill for the parts. I buy through work so I get it at cost plus I had some parts already. Grand total $0.40. I used 40 inches of 14 gauge wire, 4 ring terminals, 8 #10-24 nuts, 2 quick crimp connectors and some glue filled shrink wrapping. I would have preferred to solder the wires to the harness but the factory wires were too short so I made due.
I'm also happy to report that I passed the e-test and should be getting my sticker tomorrow.
I'll post pictures soon.
Old March 10th, 2018, 10:39   #30
flee
Fuel Economy: 40-ish
Now that sounds like a pretty solid fix/upgrade.
Always better to crimp than solder, too.
2002 Jetta GLS TDI wagon
flee is offline   Reply With Quote
Ontario Goverment's Plan for TDIs Pablo556 Ontario 131 November 23rd, 2015 10:27
car takes a while to get to normal temperature mezedg Upgrades (non TDI Engine related) 4 April 9th, 2015 02:20
Car takes several cranks before it starts vf60 TDI 101 9 September 25th, 2009 15:19
car takes about 3-5 seconds to start environmentalteach TDI 101 10 September 23rd, 2006 15:03
Permanent Fix for Glow Plug CEL (P0380)? tdi94087 VW MKIV-A4 TDIs (VE and PD) 3 March 15th, 2006 07:26
Page generated in 0.18605 seconds with 10 queries
[Output: 126.54 Kb. compressed to 105.39 Kb. by saving 21.15 Kb. (16.71%)]
