Old March 4th, 2018, 14:39   #1
burn_your_money
Default Help me fix P0380 before the goverment takes my car away
I need new stickers and can't get them with the CEL on. I have an intermittent P0380.
1999 Beetle ALH 5 speed
So far I've done the following:
Confirmed power at the harness (it's only 9v with the glowplugs hooked up)
Confirmed all plugs are 0.6 ohms cold
Soldered the 2 glow plug wires together
Cleared the code
Considered moving to an area with no e-testing
I was pretty sure soldering the 2 wires together would solve my issue but it didn't. I'm suspecting it's because I'm only getting 9v at the harness (that's with the glow plugs hooked up though). I did go in VCDS and increased my glowplug duration back at the beginning of winter, I think I'm going to try lowering that as much as possible to see if it helps.
What should I look at next? My sticker is already expired so I'm on borrowed time. Worst part is I have a trip to the USA coming up in 2 weeks and I'd rather not cross the border with expired stickers.
I buy core TDI pumps. PM me for details
burn_your_money is online now   Reply With Quote
Old March 4th, 2018, 14:57   #2
maxmoo
An intermitant p0380 is almost always a poor connection between the harness and the glow plugs.
These harnesses do fail over time.
The proper remedy is to replace the harness.
Sometimes carefully wrapping a tiny piece of aluminum foil over just the contact pin on the glow plug and re-installing the harness will make a better connection.
BTW....A simple way to test ALH glow plugs is to use a test light....clip the aligator clip on the positive battery terminal and touch the probe to the top of each glowplug contact....if the plug is good the light will light up, since there is continuity to ground.
maxmoo is offline   Reply With Quote
Old March 4th, 2018, 15:40   #3
burn_your_money
Doesn't splicing the 2 wires together trick the ECU into thinking everything is fine even if there is a poor connection?
Old March 4th, 2018, 15:57   #4
steve6
burn.. does it come back right away? you're allowed not ready monitor. If you reset the codes, drive around until all but one is not ready and take it in youll be good. Its not a solution but it will get you your stickers. Also, you can pay for a diagnostic fee from a shop and hope their quote comes in more than $450 and they will give you a conditional for two more years
I hate e-testing but with the new odb only scanning you can almost manipulate the test easier than the tail pipe testing.
steve6 is offline   Reply With Quote
Old March 4th, 2018, 16:14   #5
burn_your_money
I didn't know that we are allowed 1 not ready. I got 2 days from clearing the code to the light coming on again so I'd have to time it perfectly assuming that the other monitors were all ready.
I've never had to do an e-test before. I'm aware of the $450 bribe but I'd rather not dump that much money into the car.
Old March 4th, 2018, 16:28   #6
Genesis
Fuel Economy: 53/48/42
If you get 2 days then you have an intermittent and it's probably in the harness itself. I had something similar happen with my '03 (different setup on the glowplug harness as it checks each plug individually) where I could clear the code and clean up the plug ends with a small wire brush but it would still come back in a few days. The only way I was able to stop it for good was to replace the harness itself.
I could have spliced wire and ring terminals into the wiring along the way but given how much of a pain it is to un-loom that thing I found it MUCH easier to buy a replacement harness, plug the new one in at the plenum connector and use some cable flex to route it along the existing harness loom, zip-tied into place. It's been trouble-free since other than two actual burnt-out GPs that I've had to replace in the last few years.
Genesis is online now   Reply With Quote
Old March 4th, 2018, 17:25   #7
ToxicDoc
TDI(s): 2001 Jetta
Check fuses on top of battery - one of them is for the glow plug harness. See if there's any corrosion on them (pull them and check). Also if it's the same as a 200 Jetta, relay #180 under the dash powers the circuit. I'd inspect that too for any corrosion. You can bench test it for consistent operation/connection.
If all that looks good, it's either harness or glow plugs. You can pull the plugs and measure the resistance for each of them and see if any are of out of spec. Also look inside the harness connections for corrosion there too.
If none of that addresses the issue, then I'd consider a new harness.
ToxicDoc is online now   Reply With Quote
Old March 4th, 2018, 18:11   #8
burn_your_money
Regarding the fuses on the top of the battery, is it one of the flat ones held in with the 10mm nuts or one of the 3 green fuses (30 amps I think?). I did inspect all those fuses and the green blade style ones are awful and will be replaced ASAP but the flat ones were all perfect.
I'll try threading the glowplugs and installing nuts and ring crimp things like Vince Waldon suggested in one of the threads I read. I have a hard time paying $100 for a part that's going to fail again
Old March 4th, 2018, 18:52   #9
ToxicDoc
TDI(s): 2001 Jetta
it's one of the ones that is bolted down. second in from the right (when facing them).
As for the harness, all parts can fail with time. My harness is 17+ years old and still works fine. So I don't know if one is "going to fail again" for you in the reasonable time you'll likely own the vehicle.
Old March 4th, 2018, 19:44   #10
burn_your_money
Well that makes it a bit more worthwhile then. The way I was reading it, it seemed like a semi-annual thing to replace. Thanks.
Old March 4th, 2018, 21:50   #11
ToxicDoc
TDI(s): 2001 Jetta
Yours is presumably 19 years old. You could get 20 out of the next harness...
Old March 4th, 2018, 22:10   #12
burn_your_money
No, mine's already been replaced at least once by the previous owner. I think I'll remove, test and thread them. It doesn't seem too bad of a job to do.
Old March 4th, 2018, 22:51   #13
Genesis
I replaced mine once at ~5-6 years of age on the vehicle, and the replacement has been fine with no problems since.
Old March 5th, 2018, 04:36   #14
maxmoo
I'm sorry but that's plain silly.
Do you put tires,brakes etc,etc on your vehicle occasionally?
The glow plugs are designed to help your tdi start not just to pass an emisions test....why wouldn't you want a functioning glow plug system?????
Old March 5th, 2018, 05:16   #15
jimbote
jimbote's Avatar
He's talking about making a bolt on harness not eliminating the glow plugs
Ontario Goverment's Plan for TDIs Pablo556 Ontario 131 November 23rd, 2015 09:27
car takes a while to get to normal temperature mezedg Upgrades (non TDI Engine related) 4 April 9th, 2015 01:20
Car takes several cranks before it starts vf60 TDI 101 9 September 25th, 2009 14:19
car takes about 3-5 seconds to start environmentalteach TDI 101 10 September 23rd, 2006 14:03
Permanent Fix for Glow Plug CEL (P0380)? tdi94087 VW MKIV-A4 TDIs (VE and PD) 3 March 15th, 2006 06:26
Page generated in 0.18884 seconds with 10 queries
[Output: 125.04 Kb. compressed to 104.33 Kb. by saving 20.72 Kb. (16.57%)]
