Old March 4th, 2018, 14:49   #1
erickSD
TDI(s): 2009 jetta
Default Jetta TDI 2.0 overheating solved
Hello
Some days ago my 2009 jetta 2.0 start developing overheating when under acceleration, I'd replace sending units, radiator, thermostat, water pump, Heather core...any of this replacements solve the problem.
I'd check EGR and found this valve stuck open...cleaned it with carbu_clean spray and for my surprise OVERHEATING PROBLEM WAS SOLVED.
ONLY additional option was headgasketh...I'm glad was not necessary to replace it.
Best regards!!!
erickSD is offline   Reply With Quote
Old March 4th, 2018, 15:56   #2
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
which EGR valve ? There are two. Did you have a code for EGR valve stuck?
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old March 6th, 2018, 07:50   #3
JETaah
Fuel Economy: 53 max, 42 min, average 46
Glad your problem has been solved.
Seems like if your car had an EGR valve stuck open you would have had trouble accelerating.
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is online now   Reply With Quote
2006 Jetta TDI overheating stevea841 TDI 101 10 July 3rd, 2015 09:54
Odd overheating problem SOLVED imo000 VW B5 Passat TDIs 3 March 17th, 2015 15:08
09 Jetta TDI Overheating Whiteboy84 VW MKV-A5 Golf/Jettas 12 September 25th, 2014 15:00
overheating solved manonfire TDI 101 1 December 19th, 2013 05:12
2001 jetta TDI 1.9l overheating issue, need help!!! plainsong VW MKIV-A4 TDIs (VE and PD) 11 March 21st, 2012 07:10
Page generated in 0.09293 seconds with 10 queries
[Output: 57.98 Kb. compressed to 52.61 Kb. by saving 5.37 Kb. (9.26%)]
