Old March 4th, 2018, 13:04   #1
Cdownard
Default 2004 jetta BEW tdi stalling/no start
Hi everyone sorry if this is not where to post this I am New, I have a 2004 jetta BEW tdi, last week I was driving on the highway at about 70km/h and I lost power I pulled over and the car stalled it would crank but not start, I towed it home got to look at it found the egr full of carbon, I cleaned it up and pulled the intake elbow tube off, now it starts but stalls if I put the intake tube back on, I have very little exhaust coming out so I drilled a hole pre cat to check if the cat was plugged, still same issue, very little exhaust coming out of the hole I drilled as well, I'm pretty sure I have an air restriction somewhere or something like that I was just wondering if anyone had any insite on where i should be looking for it , with the elbow off it idles fine but as soon as i put it close it stalls out any info would be appreciated
Cdownard is offline   Reply With Quote
Old March 4th, 2018, 13:35   #2
Alchemist
TDI(s): '04 ALH Golf
I have seen a similar situation before, and it turned out to be the turbocharger had failed blocking the air and exhaust paths.
I've learned so much from my mistakes I'm thinking of making some more.
Alchemist is offline   Reply With Quote
Old March 4th, 2018, 13:40   #3
Cdownard
Is there a way to diagnose the turbo
Old March 4th, 2018, 16:10   #4
maxmoo
Get underneath and remove the intake air hose from the turbo so you can check the impeller for damage or seizure.
maxmoo is offline   Reply With Quote
Old March 7th, 2018, 20:41   #5
Wilkins
Fuel Economy: 4.6/5.6 - 5.3/6.7
Pull hose off intercooler. Is it full of oil? Common symptom of turbo failure.
2005 Jetta Wagon: Evo skid plate, Kerma Tune, Moog VR6 front springs, Koni Reds, Jeff's HID's, Upgraded door switches!. MKVI: Containflo+Pureflo, Rear Tiggy springs and B6 Billies, Xenon w LED, AFS, 087T BCM
Wilkins is offline   Reply With Quote
Old March 7th, 2018, 22:22   #6
whitedog
We ran into this here a few weeks back and I suggested the same thing, but if it's full of oil, you still need to pull the intake off the turbo to verify that it has failed. But if the turbo is failed, you need to pull the hose off of the intercooler to drain the oil.
I guess one problem with starting with the intercooler hose is what if it's NOT full of oil, but the turbo has still failed, but you didn't check the turbo?
But will a failing turbo ALWAYS fill the intercooler with oil? Maybe it will and maybe I'm just overthinking this. And what if the turbo HASN'T failed and you go through all of the work to get the ar up, crawl under, figure out which tools you need, crawl back out, get the wrong tools...
Ah Heck. Just pull the danged intercooler hose and stop overthinking the silly thing!
2004 Jetta BEW wont start! busa_chris VW MKIV-A4 TDIs (VE and PD) 33 May 18th, 2016 17:33
2004 jetta tdi BEW stalling problems anything diesel VW MKIV-A4 TDIs (VE and PD) 3 April 2nd, 2016 11:02
Clock and trip meter reset, occasional stalling. 2004 BEW calebc3 VW MKIV-A4 TDIs (VE and PD) 10 August 14th, 2013 19:37
2004 jetta tdi pump duse bew cold hard start Windmu20 VW MKIV-A4 TDIs (VE and PD) 21 February 9th, 2013 20:55
2004 Jetta TDI BEW Engine Wont Start kcox69 VW MKIV-A4 TDIs (VE and PD) 14 September 16th, 2010 05:52
Page generated in 0.14191 seconds with 10 queries
[Output: 74.13 Kb. compressed to 64.84 Kb. by saving 9.28 Kb. (12.52%)]
