Old March 8th, 2018, 12:01   #16
Judson
TDI(s): 2001 Jetta
OK, latest log, first attempt at this. Sadly, after WOT run, very loud high pitch whine coming from engine. RPM-related, remained even if clutch pushed in. Diagnosing, but it's not a good sound. All boost tubes in place and look good. Whine louder from above engine, hardly any whine from below. Sigh.
2001 Jetta TDI, converted to manual, black leather/red stiching, PP520s, rc4, franko6 cam, 11mm pump, VNT 17, PD150 intake, EGR/cooler delete, 2.5" Buzzken exhaust, PD150 clutch/flywheel, DRW six-speed, Eurojet intercooler, 3bar MAP, FIS Cluster, Cupra bushings, Koni Reds/stock springs, Alpine iLX-207, foglights, Indiglo boost gauge, Longbeach wheels, Euro wood steering wheel, lift pump, Gentex autodim/homelink mirror.
Judson is offline   Reply With Quote
Old March 8th, 2018, 12:25   #17
jimbote
jimbote's Avatar
remove your serpentine and see if the noise goes away... serpentine idlers, rollers, and even the alternator can make a whine
Old March 8th, 2018, 12:36   #18
Judson
TDI(s): 2001 Jetta
Yeah, just did that at the advice of my mechanic. Didn't make a difference.
Honestly, sounds to me like it's coming right from the injection pump...!!! ????
No whine from below at all. But he believes that it's the output side of the turbo that's machining itself.
A new VNT17, no less. He may come up and take a look in person. I clearly can't drive it to his place.
Old March 8th, 2018, 15:13   #19
Judson
TDI(s): 2001 Jetta
Pic of cold (airbox input) side of turbo:
Does that look right? I have no idea.
Thanks all.
Old March 8th, 2018, 16:18   #20
jimbote
jimbote's Avatar
turbo is trashed
Old March 9th, 2018, 08:51   #21
Judson
TDI(s): 2001 Jetta
Hey Jimbote -
Talked with Jeff - you're right, unplugged the MAF should run better if the MAF was bad, as he put in a stock program for MAF-less situations.
He also says that the vendor I received my turbo from has been known to use Chinese turbos. Guess we'll see if I get a refund.
Needless to say I'll only be getting stuff from IDParts, or via my mechanic in the future. At least my mechanic will fully warrantee stuff - install and all.
Old March 9th, 2018, 10:59   #22
jimbote
jimbote's Avatar
can you share what vendor ? pm me if want it kept confidential
Old March 9th, 2018, 11:33   #23
Nevada_TDI
Dutch Auto Parts is a trusted vendor of turbos, transmissions, and many other ALH parts and he has very reasonable prices.
_______________
2001 Jetta GL TDI, Tinted, Ventectomy, Catectomy, EGR-ectomy, TDTuning, HIFLO .216's, Stealth 17/56 Garrett, VCDS Hex+CAN, South Bend Daily Driver 2 Clutch, DG Short Shifter, Frostheater, Baldwin Fuel Filter, Previous Diesel: 1983 Rabbit Diesel
Nevada_TDI is offline   Reply With Quote
Old March 10th, 2018, 08:38   #24
Judson
TDI(s): 2001 Jetta
If I was the guy doing all of the work, then yes, I'd buy/install myself. But I'm not. There are some jobs I leave to people with 1000x more hours working on cars than myself, and there are some jobs I can do myself without effing anything up, and can easily recover from if I do.
I have learned to never underestimate decades of experience of wrenching versus a shade tree mechanic's skills.
Boost logs look ok here? firehawk618 TDI Power Enhancements 4 June 28th, 2012 13:52
help, final check of logs before road trip GuyGuy TDI Power Enhancements 3 July 10th, 2011 20:38
Have an over boost, what logs?? Fox_Kid_263 OBD Scanners 4 March 22nd, 2008 13:41
a couple of logs with graphs. Boost and MAF claytski VW MKIII-A3/B4 TDIs 6 January 3rd, 2008 18:50
Guru's pls check these logs and comment - Suspect MAF TDIFanatic1.9 TDI 101 7 September 19th, 2007 05:42
Page generated in 0.14386 seconds with 10 queries
[Output: 93.58 Kb. compressed to 79.99 Kb. by saving 13.59 Kb. (14.52%)]
