Old March 3rd, 2018, 09:35   #1
mhintlian
TDI(s): 03 Golf GLS
Default Mk4 ALH Exhaust Downpipe
2003 Golf GLS Mk4 5 spd 369,000 miles, original owner. I rebuilt the engine and tranny 50,000 miles ago. Kept the original exhaust system. It appears that upon start up that exhaust fumes are leaking out of the flex part of the downpipes. Upon searching for a replacement downpipe there are numerous available. ID Parts, my trusted parts supplier, has a downpipes with a catalyst that has a disclaimer that the catalyst does not meet the peoples socialist republic of California standards. However, the "smog check" for a TDI is just a plug into the "D" plug under the dash, no exhaust gas analyzer up the exhaust pipe. So if I get the downpipe with the catalyst from ID Parts what is the probability that my vehicle will not pass the "smog check"? Or If I replace the downpipes with one that does not have a catalyst, will that effect the readiness reading? I still have the EGR connected and have no plans of removing it. Everything else is stock.
Any and all replies are truly appreciated.
Mhintlian
mhintlian is offline   Reply With Quote
Old March 3rd, 2018, 10:06   #2
maxmoo
First off, I know nothing about Calif. emisions testing.
Here in Ontario, Canada the emisions test only checks for fault and rediness codes.
Deleteing the cat will not trigger any codes on ALH vehicles.
We have been using 2.5 inch catless downpipes from various venders for quiet a few years now.
I find it helps milage and performance slightly and it does lower exhaust gas temp significantly.
"Buzzken" makes a reasonably priced 2.5" dp that steps down to OE dia so you can easily connect to your original exhaust.
That way you can easily add a "cat back" 2.5" exhaust later if desired/needed.
http://www.fixmyvw.com/mk4-tdi-stain...s-bew-and-alh/
maxmoo is online now   Reply With Quote
Old March 3rd, 2018, 10:59   #3
tyberesk
tyberesk's Avatar
Just recently dealt with this, but in Denver, Colorado (which is now following California rules). Any modification between between turbo and outlet of cat must be OEM. I had to pull out my buzzken downpipe and cat and replace with OEM when I moved here as I failed the visual inspection (even though I passed the opacity tests). Lucky for diesels in CO, a replacement used OEM downpipe/cat was an acceptable loophole.
Edit: Catback exhaust modifications are allowed and not under scrutiny here. Also, universal cats (like a genereric magnaflows) are no longer being accepted here.
tyberesk is offline   Reply With Quote
Old March 3rd, 2018, 11:40   #4
BobnOH
not-a-mechanic
Fuel Economy: 50/45/35
Interesting. Here in Ohio they can't sell used catalytic converters.
Can you keep your Catalytic Converter, just replace the down pipe.
Or can you just install this?
For the mileage, the trouble, the inspections, you may want to get under there and see exactly where it is leaking. Perhaps you can r+r back to life.
Old March 3rd, 2018, 12:11   #5
Genesis
Fuel Economy: 53/48/42
Are you sure out in CA they don't do a visual inspection to see if all the CARB-required bits are indeed present and stamped CARB-approved?
In a lot of areas they are visually inspecting as well nowdays as they've become wise to people being able to tune out the CEL or "readiness" bits not being set.
Genesis is online now   Reply With Quote
Old March 3rd, 2018, 12:27   #6
ToxicDoc
TDI(s): 2001 Jetta
If your vehicle is stock and needs all oem equipment, why not just price a downpipe/cat from VW? Get the part number and do comparison shopping
ToxicDoc is online now   Reply With Quote
Old March 4th, 2018, 06:14   #7
tyberesk
tyberesk's Avatar
I was quoted around 1200 for the oem downpipe/cat in PA and 1400 in CO. Until I found the used OEM cat loophole here, it was turning into a nightmare.
Old March 4th, 2018, 08:23   #8
ToxicDoc
TDI(s): 2001 Jetta
Wow, that's some real legislative BS. My personal solution would have been to try to disguise an aftermarket unit as OEM lol.
Old March 5th, 2018, 20:18   #9
FasterXR4ti
Fuel Economy: 47 Avg
Why not just remove your stock down pipe, purchase a replacement flex section, take to a welding shop, and have them replace just the flex section. I do my own welding, so that's what I did.
97 Passat TDI Sedan Silver, Victim of bad driver (my parts car)
97 Passat TDI Sedan Silver, Hella e-codes, Auto-dimming RV mirror.
2000 Golf GLS TDI Auto, Still running @ 300K
2009 Camry Hybrid, Wife's car (She always gets the best)
FasterXR4ti is offline   Reply With Quote
Old March 6th, 2018, 02:09   #10
burn_your_money
I've heard the BEW ones last longer than the ALH. You could swap in the whole shebang, cat and all.
I buy core TDI pumps. PM me for details
burn_your_money is offline   Reply With Quote
Old March 6th, 2018, 06:17   #11
Prairie Chicken
Mhintlian - +1 with BobnOH... I'm guessing most muffler shops will do that (at least saw several youtube vid's of that) for not too much $$$. I did mine not long ago - got the pipe at local parts store for $30. Had I known IDparts carried those could have saved a little more...
http://forums.tdiclub.com/showthread.php?t=485548
Prairie Chicken is offline   Reply With Quote
Old March 6th, 2018, 14:23   #12
sawmilldon
TDI(s): 2004 Wagon
I just replaced my exhaust from my 2004 Wagon. I cut it in half about 3 feet past the cat.
Sitting in the shop, gathering dust.
sawmilldon is offline   Reply With Quote
Old March 6th, 2018, 17:53   #13
flee
Fuel Economy: 40-ish
I upgraded the downpipe on the 2002 and just sawed the cat to match the new diameter.
Then had it welded and it was better than new.
2002 Jetta GLS TDI wagon, 2012 Audi A3 TDI S-Line
flee is online now   Reply With Quote
MK4 ALH TDI Downpipe Florida bobbiemartin Private TDI Items for Sale/Wanted 2 May 3rd, 2017 04:13
WTB : ALH 2.5 Downpipe / Full Exhaust System systematdi Private TDI Items for Sale/Wanted 1 July 18th, 2016 20:25
WTB Downpipe for MK4 ALH TDI msev Private TDI Items for Sale/Wanted 2 August 29th, 2010 10:22
MK4 PD 3" SS Downpipe and custom exhaust fab Whitbread TDI Power Enhancements 15 May 6th, 2009 19:51
WTB: MK4 TDI Exhaust Downpipe Negawsklov Private TDI Items for Sale/Wanted 2 November 21st, 2004 14:33
Page generated in 0.18200 seconds with 10 queries
[Output: 112.10 Kb. compressed to 93.71 Kb. by saving 18.39 Kb. (16.40%)]
