Old March 3rd, 2018, 06:54   #1
Volunteer
Default Transmission code P0763
I was looking to buy a 2006 Jetta TDI automatic.The owner said it was diagnosed with a code P0763 solenoid C and the car will only shift to third gear.What is the most likely fix for this.It has 268K kms
Volunteer is offline   Reply With Quote
Old March 3rd, 2018, 07:59   #2
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Mechatronic is most likely. Very expensive but maybe you could find a used one.
There have been a few solenoid codes on those fixed by poor connections to those solenoids. Maybe resoldering cracked solder joints or other types of repairs like that.
I recently saw circuit plates available for these, but this would take advanced skills to replace. Used or new from Vw is probably the way to go.
Valve body rebuilders seem to have started offering these. I have no idea on price or quality.
Edit: I just thought that since you posted a "p" code that its possible there are other codes in there, and it could be that the trans has a internal failure along with the solenoid code. Might want to get scanned with vagcom before you commit to anything.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old March 3rd, 2018, 11:39   #3
Volunteer
The owner says he 9 new solenoids and will install them when the weather warms up.I said to let me know when that is done and the transmission is working properly.
Old March 4th, 2018, 15:46   #4
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
Riiiggghhhhhtttt......
caveat emptor
Transmission Code 993er TDI 101 1 June 3rd, 2014 21:13
Transmission code ekkoh99 VW B5 Passat TDIs 3 September 14th, 2011 20:32
Transmission Code? Jeepmb TDI 101 1 September 21st, 2008 19:30
2002 Jetta CEL + P0763 Code Osito VW MKIV-A4 TDIs (VE and PD) 8 December 20th, 2007 12:34
HELP!! Transmission Code Hobhancock TDI 101 3 May 31st, 2007 18:03
Page generated in 0.11990 seconds with 10 queries
[Output: 63.62 Kb. compressed to 56.97 Kb. by saving 6.65 Kb. (10.45%)]
