Old March 3rd, 2018, 04:47   #1
Henrick
Exclamation Balance shaft hex key remedy
Hello everyone.
Past days I see a lot of cars which lose oil pressure because the damn hex key simply rounds off its edges to a point where it can no longer drive the oil pump.
I have heard of various possible remedies for this, such as thicker hex keys, welding them into balance shaft, etc... But I am not sure how reliable are those methods and which one should I go with.
So the question is what is the actual permanent and long term remedy for this? Replacing the hex key with a new OEM one usually just postpones the problem to next 40-60k km before it gets rounded off again (there is already some play inside the balance shaft and the new hex key, that's what causes wear IMHO).
Thanks.
Henrick is offline   Reply With Quote
Old March 3rd, 2018, 07:01   #2
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
deleting the balance module is a good solution.
Richard. ASE Certified Master Auto-Technician with L1 Advanced Engine Diagnostic Rating. ATRA Certified in Rebuilding, Diagnosing & Installing Transmissions.
LOOK AT MY YOUTUBE CHANNEL -->
https://www.youtube.com/user/CoolAirVw/
Now offering Malone Tunes!..............http://www.kansascitytdi.com/
CoolAirVw is offline   Reply With Quote
Old March 3rd, 2018, 08:56   #3
JSWTDI09
JSWTDI09's Avatar
Yeah, basically turning a CBEA into a CJAA engine (or at least changing the way the oil pump is driven with CJAA parts).
Have Fun!
Don
JSWTDI09 is offline   Reply With Quote
Old March 4th, 2018, 12:03   #4
Henrick
I have heard quite a few cases where crankshaft gets broken after this. Not sure how much is truth and reality in this.
Besides, it's quite costy and labour intensive operation. Not many owners will agree.
So any realistic solutions when the BSM stays in place?
Old March 4th, 2018, 13:31   #5
TheGrove
If you search in the B5 forum (http://forums.tdiclub.com/forumdisplay.php?f=65) there seemed to be 2 hex key lengths for the BHW engine. The short key had a tendency to round off while the longer key was better because it went deeper in both the BSM and Oil pump. Not sure if the same is true for your engine, but it was a thought.
2012 Passat SEL Premium TDi Opera Red - Dieselgate Fix, KermaTDI Tune
2004 Passat GLS TDi Northern Green RC Stage 2 Chainless - RIP
TheGrove is offline   Reply With Quote
Old March 4th, 2018, 14:54   #6
CoolAirVw
CoolAirVw's Avatar
TDI(s): Jetta
Fuel Economy: 40
I have heard quite a few cases where crankshaft gets broken after this. Not sure how much is truth and reality in this.[/QUOTE]
There is none. I've done at least 15 (probably more) on Bhw (04-05 passat) Only way a crankshaft might break is if it was Butchered during the job. For instance if someone didn't have the right tool to get the crank gear off.
I just realized that I assumed you had a b5 passat when I answered. Is that what you have?
I certainly dont agree. (b5 passat)
If you have a b5 passat you just gonna leave the chain in there with the BM till the chain fails? If you dont have a b5 passat disregard most of what I said.
Old March 5th, 2018, 01:32   #7
Henrick
No, it's not the Passat BHW.
I'm from Europe, there are more similar engines, both PD and CR. E.g. CBBB.
I am aware of different lengths of keys, 72 mm and 100 mm. But You can't just toss longer key in into 72 mm balance shaft design...
Is it somehow possible to spot weld the key in place?
Old March 5th, 2018, 07:47   #8
JETaah
Fuel Economy: 53 max, 42 min, average 46
The hex shaft is probably what it is because it needs a little flexibility to the mechanism for ever so minor misalignments, or the like. They could have made some sort of press fit drive components if it was not.
Get rid of it! So much trouble and expense for a minimal return. Why don't the BRMs, BEWs, break crankshafts? None of the dozen or more cars that I've changed over have come back with broken cranks.
1999.5 a4 Jetta, port matched, RC2, sprint 520's, 1.5" lift kit
1996 Passat B4V, coat hanger supported exhaust system,
Visit me www.martinbergelllc.com
JETaah is offline   Reply With Quote
Old March 5th, 2018, 08:47   #9
Windex
Windex's Avatar
Fuel Economy: ʎɯouoɔƎ lǝnℲ
IIRC there is a boutique machine shop outfit in the UK and a few of them in the EU that will machine a larger hex recess into the BSM.
Proudly installing things where they're not supposed to go since 1996!
Windex is offline   Reply With Quote
Old March 6th, 2018, 00:07   #10
Henrick
^-- yeah, that's what I expected to hear. In fact I think you need something like oversized hex hey, e.g. 6.2 mm or so.
Any links/hints on how to locate it? I've done some google as well as looked on ebay and found none...
Old March 6th, 2018, 06:29   #11
Windex
Windex's Avatar
Found this:
https://www.ebay.ca/itm/VW-Passat-Je...NaK6Ot&vxp=mtr
I have a gear driven module set aside with the 77mm key - thinking about having them quote on re-doing it with the 100mm key.
Right now I'm BSM deleted.
Old March 7th, 2018, 00:25   #12
Henrick
Interesting. Seems they somehow modify the shaft itself.
Balance shaft module with "short" 70mm oil pump drive shaft tikal VW B5 Passat TDIs 7 December 24th, 2016 18:48
FS: Complete BHW Cylinder head, geared balance shaft with new hex drive newlitemotorist Private TDI Items for Sale/Wanted 5 January 14th, 2015 10:18
balance shaft failure/hex key CR tdi engine vw754 VW MKV-A5 Golf/Jettas 2 November 20th, 2013 16:01
Balance shaft JeffOB TDI 101 4 November 2nd, 2011 22:27
New Balance Shaft Module Hex Drive Loose onakaw VW B5 Passat TDIs 14 February 22nd, 2011 19:40
Page generated in 0.12217 seconds with 10 queries
[Output: 109.74 Kb. compressed to 92.56 Kb. by saving 17.17 Kb. (15.65%)]
