Old March 2nd, 2018, 19:14   #1
TDI(s): 3.0
Default 3.0 gen 2 fix, immediate engine codes and weird idle
Got the fix on my 2014 A6, and got two engine codes for check engine within 1 mile from leaving the dealer.
P010, intake mass air flow.
Then second for EGR insufficient flow.
Dealer also has my 2014 Cayenne Diesel, and the car did not accept the update and now the car is underivable. They're waiting on Porsche to figure out what's wrong with ecu blah blah blah more delays.
The fix is off to a bad start.
Zawurah is offline   Reply With Quote
Old March 2nd, 2018, 20:49   #2
TDI(s): A7
I'd take the car straight back to the dealer. Maybe the car was close to a regen and they flashed, thus throwing poor ERG code.
Just had my A7 TDI fixed this week. No codes, but again I haven't checked. I've been driving the car hard, setting adaptations before I check.
Burnt is offline   Reply With Quote
Old March 3rd, 2018, 07:39   #3
Moderator at Large
Mass air flow and EGR codes could be related, since these engines use the mass air flow sensor to regulate the operation of the EGR. Since it happened so soon after the fix, someone forgot to connect a hose or plug something in, or something of that sort. Take it back and tell them to fix it.
Brian P.
formerly ... 2006 Jetta TDI 5-sp, Spice Red, Unitronics stage 1, 0.681 5th gear.
and before that ... 1996 Passat TDI, Silk Blue
Old March 5th, 2018, 14:54   #4
TDI(s): 3.0
Dealer found EGR leak, and leak on intake manifold.
Both of these are covered under extended warranty, but dealer is playing dumb and denying denying denying.
Time to call Audi customer service. The settlement terms explicitly say EGR, long block, and even check engine light.
Appears to be a Fix for Gen 1 cars! Gen 2-3 are Software. BleachedBora Dieselgate - VW Group Emission Scandal 592 October 12th, 2017 10:46
Gen 2 vs Gen 3 after emissions fix? Rick_Brown Dieselgate - VW Group Emission Scandal 4 September 20th, 2017 13:35
Now that the Gen 1 fix is out: Contemplating the Gen 3 for Gen 1 swap toneman Dieselgate - VW Group Emission Scandal 50 August 20th, 2017 22:48
VW's 1st D Day, November 11th. Gen.1 engine fix or no go? lewisfromindy Dieselgate - VW Group Emission Scandal 5 November 14th, 2016 05:58
Page generated in 0.10691 seconds with 10 queries
[Output: 60.91 Kb. compressed to 54.49 Kb. by saving 6.41 Kb. (10.53%)]
