Old March 1st, 2018, 23:07   #1
iamatt
iamatt's Avatar
Fuel Economy: 45
Default Reset p3 gauges to default settings?!
Does anyone know how to reset the P3 gauges to default settings?! This is a 2014 Jetta TDI. Must have hosed something up by accident. The gauges display 0 for a value and blink real fast. About to throw this thing out the window
2014 Jetta TDI sedan (new) ,2014 TDI Jetta Sport Wagon 6MT (Flooded) Amsoil HDD3000 20K OCI, GSP Mod (RIP Rosie 4/4/2015), 2011 Toyota 4 Runner SR5 (Flooded), 2007 Duramax (Flooded), slightly modded GSPv2 is here, Bellatrix "Bella" Hunting God's County, katygsp.com
Amsoil Dealer -
http://www.texas-synthetics.com
iamatt is offline   Reply With Quote
Old March 2nd, 2018, 08:02   #2
JSWTDI09
JSWTDI09's Avatar
I do not know the answer to your question and I assume that you have already unplugged it and plugged it back in (probably more than once).
My only suggestion would be to contact P3Cars and ask them before you throw it out the window. If you go to their FAQ page you will get a chat link. Maybe they can help you.
http://www.p3gauges.com/faq/
Have Fun!
Don
P.S. Can you get it to go into the configuration menus, or is it totally dead?
JSWTDI09 is online now   Reply With Quote
Old March 5th, 2018, 19:46   #3
iamatt
iamatt's Avatar
Fuel Economy: 45
No way to reset according to P3 chat guys. Got things back on track but they did say latest Malone tunes block their boost reading so need to go analog.
Amsoil Dealer -
Old March 5th, 2018, 20:09   #4
Owain@malonetuning
All other tools read boost fine, measuring block 11 along with advanced blocks function like normal, and mechanical gauges match VCDS readouts. This is the only tool we've seen act up. Not sure which channel they're reading off of but we're not blocking anything. Could probably make some form of work around if we knew which channel they were reading off. Will shoot them an email, messing around with edge insight units as well, they can log mechanical inputs.
Dealers - malonetuning.com/dealers
We made a free VCDS Log Viewer!
Owain@malonetuning is offline   Reply With Quote
Default settings list for VAG-COM? romad TDI 101 2 December 14th, 2011 13:27
Default settings? acmercg OBD Scanners 7 November 29th, 2010 19:10
Gauges won't reset to 0. cjharris02892 TDI 101 4 January 11th, 2010 18:20
resetting auto trans default shift settings? stepetrhick TDI 101 1 May 28th, 2004 07:23
if you were going to install gauges whats your top three most important gauges? Y2K BORA TDI Power Enhancements 39 December 13th, 2001 00:49
Page generated in 0.11503 seconds with 10 queries
[Output: 66.25 Kb. compressed to 59.19 Kb. by saving 7.06 Kb. (10.66%)]
