Old March 1st, 2018, 20:48   #1
BeetleDragon737
BeetleDragon737's Avatar
Fuel Economy: 40.5 MPG
Default Swapping LEDs in Autometer Gauges
I'm looking to install these two gauges (boost + EGT) before I get RC3 on my Beetle:
https://www.egauges.com/30-inHg-30-P...p/atm-3803.htm
https://www.egauges.com/1600F-EGT-2-1-16-p/atm-3844.htm
Only problem is, these gauges come with a green LED backlight which doesn't match the blue in the car. I'm curious whether anyone has had luck removing the colored LEDs from Autometer gauges and putting in different ones.
For the standard bulb gauges, the lights can apparently be swapped for various color LEDs. However, I emailed eGauge customer support, and they gave a very short reply saying that it's not possible for gauges that come standard with LEDs. I am doubtful of that though. Surely there must be just a few screws to undo in order to access the circuitboard in the gauge, right?
Current things:
DG skid plate, South Bend S2D clutch
Planned things:
RC3, DLC 520 injectors, mufflectomy, EGT/boost gauges
BeetleDragon737 is offline   Reply With Quote
Old March 2nd, 2018, 09:46   #2
hey_allen
Based on the information in the instruction manual linked on the first egauges link, it appears that they have a replaceable bulb in a holder.
If it's anything like the older AutoMeter gauges that I worked with years back, it likely just has a green colored boot over the light source.
Even if it isn't, you could probably replace the green LED with a blue LED from somewhere like Superbrightleds.com once you identify what the socket looks like.
If this is actually an internal light source, it would involve disassembling the gauge, desoldering the LEDs from a circuit board, and replacing them with blue LEDs of the appropriate size and voltage. Still not an issue if you're skilled with a soldering iron, but a lot more involved.
Simpler by far would be to take a look at the AutoMeter Cobalt series of gauges, which are blue to start with.
hey_allen is offline   Reply With Quote
Old March 3rd, 2018, 07:06   #3
Jetta_Pilot
Jetta_Pilot's Avatar
Location: West Hill, Ont. Mexico mid October 2017 to end of April 2018
Installing LEDs requires much care, correct polarity is one. Too much heat can blow a LED, so ideally a heat sink is required along with a low 20W soldering iron. A heat sink can be as simple as a small alligator clip on the LED leads.
All interior bulbs to LED. Several VCDS modifications. Darker window tint. EVO skid-plate. Malone Stage 2, Winpower Projector headlights. Angel eyes.LED DRL's.24mm H&R rear sway bar.
Jetta_Pilot is offline   Reply With Quote
Old March 5th, 2018, 14:21   #4
STOKTDI
Like stated the color used to be achieved by crappy colored sleeves over an incandescent bulb. I bought green led replacement bulbs straight from autometer and they were simply a short 194 bulb. Took two seconds to take the gauge apart and replace. Those were ford factory match gauges but assuming autometer is consistent along different platforms?
STOKTDI is online now   Reply With Quote
Old March 5th, 2018, 17:04   #5
PB_NB
PB_NB's Avatar
I switched out all the gauges in my Vanagon to Autometer and then switched the bulbs to blue LEDs. The version of gauge I had allowed for a bulb replacement so I got some little push in bulbs (not too sure of the size) from the local auto parts store.
If you want to change the color of the bulb, look for a gauge that takes replacement bulbs.
I have digital blue gauges in the Beetle with a 2 pod housing.
1999 New Beetle TDI - Bosio 1019's, Malone S4, Skid Plate, Neuspeed Sway Bars, KW V2, 19's BBS-CH, Spyder LED's, EGR Delete, VF Mounts, South Bend Clutch, B&M Shift Kit, VNT17, Custom Side Mount Intercooler, HPA Big Brakes 355mm Ft/335mm Rr, 2.5" Custom SS Straight Through Exhaust, Colt Stage 2 Cam, 3 Bar Map.
PB_NB is offline   Reply With Quote
Old March 5th, 2018, 23:09   #6
BeetleDragon737
I know with these specific gauges, there is no incandescent bulb that can be simply swapped out. I'm fairly certain these LEDs are soldered to the board directly. That instruction manual seems like a generic one for all Autometer gauges. I chose these gauges because the styling looks nice and matches with the interior, and they're priced well. Some other ones are more than twice the price for the boost gauge.
The Cobalt ones would definitely be a good other option, but I don't like the styling on them too much.
I'm fine with a soldering iron. The question is whether these LED gauges can be disassembled easily. Does Autometer typically do a good job with making their gauges easy to disassemble? I don't want to buy the gauge and find that I have to break it in half to get at the circuit board.
Current things:
Planned things:
Scangauge2/Autometer Gauges questions ss04vv OBD Scanners 5 October 5th, 2011 16:45
F.S. AutoMeter Phantom Gauges truszip Private TDI Items for Sale/Wanted 2 February 8th, 2009 12:14
F.S. AutoMeter Gauges truszip Private TDI Items for Sale/Wanted 1 January 14th, 2009 08:19
Autometer Cobalt gauges dhdenney Private TDI Items for Sale/Wanted 6 October 10th, 2008 06:54
Autometer Gauges? doc_m Upgrades (non TDI Engine related) 7 March 30th, 2006 09:39
Page generated in 0.13784 seconds with 10 queries
[Output: 76.51 Kb. compressed to 67.16 Kb. by saving 9.35 Kb. (12.22%)]
