Old March 1st, 2018, 19:56   #1
TDITim83
TDITim83's Avatar
Default Changing Injection Quantity issue
I have been on VAG Com and I can't seem to be able to drop my Injection Quantity low enough. Instead of being around, 3.2 I am above 6. And am only able to adjust it down to 5.8 at best. What am I missing?
TDITim83 is offline   Reply With Quote
Old March 1st, 2018, 20:06   #2
jdulle
I think what you need to do is loosen the bolts on the top of the injection pump and tap in the direction that lowers injection quantity. You should search for the procedure and follow those instructions, the top of the injection pump needs to move only a fraction of an inch. You should have the vag com connected so you can watch what is happening to IQ in real time.
jdulle is offline   Reply With Quote
Old March 1st, 2018, 20:37   #3
ToddA1
Fuel Economy: Dismal
http://forums.tdiclub.com/showthread.php?t=258297
-Todd
'96 B4V: Kerma tune and PP520s
'97 B4: Stock
Rabbit build
ToddA1 is online now   Reply With Quote
Old March 2nd, 2018, 04:09   #4
Tdijarhead
Here is a video of the hammer mod. As you watch it keep in mind that you do not need to hit the pump very hard. Maybe it just the video and a light hammer but it seems like these guys are really beating on that pump.
You will need the triangle bit to get the one bolt loose. Or hammer a 12 point socket down over it. The other three are torx.
They are raising the IQ and you need to lower yours so you’ll be going in the opposite direction. If you have one I would use a rubber or plastic headed hammer.
https://m.youtube.com/watch?v=TL_7KN4Nbvo
Tdijarhead is offline   Reply With Quote
Old March 2nd, 2018, 08:42   #5
KLXD
After a minimum of 15 years the QA on a VE pump that has never been apart may not want to move.
Even heavy tapping may not overcome the adhered seal and when it does let go there's no telling how far it might move. Then the hardened gasket may not seal again.
I'd be prepared with a new gasket set before attempting the hammer mod.
Current: 02 Jetta, Auto; 98 Jetta, 5 Spd; 98 Dodge, 5 Spd, SB, 4x4; 84 Grand Wagoneer with Nissan SD33T, NV4500, Dana 300, Reverse Cut Dana 44, Dana 60
The Black Sheep (Only gasser): 85 CJ, 4.2 w/4.0 Head and Mopar FI.
Past: 85 Mitsubishi PU, 4D55T; 81 Rabbit, 1.6; 80 Dasher, 1.5; 79 Rabbit, 1.5
Old March 4th, 2018, 17:17   #6
greenskeeper
greenskeeper's Avatar
Fuel Economy: 53mpg
It'll move, doesn't take much to make a big impact.
On my old 98 the "sweet spot" with RC3 tuning was to adapt to the lowest IQ and then hammer to 1.5
Gunga galunga...gunga -- gunga galunga.
98 JETTA TDI (SOLD) PP764s, RC3, 5deg advanced, 0.68 5th
97 F-250 Crew Cab 4x4 7.3L PSD E4OD (stock)
99 F-250 Crew Cab 4x4 7.3L PSD ZF-6 (4" turbo back, Hydra chip)
greenskeeper is offline   Reply With Quote
Old March 4th, 2018, 18:28   #7
Mongler98
those seals are $4.00~ and easy as heck to replace. i would replace them if you so much as move it, well at least order the seals, if it leaks, then you can fix it easy, otherwise you have a $4.00 set of seals for when they eventually do leak
Old March 13th, 2018, 20:08   #8
Giberish33
Just out of curiosity greenskeeper, what was the reasoning for dropping the adaptation all the way before hammer modding? I understand that each car might want a slightly different IQ to run best, but from what I understand the general thinking around here is that you should keep adaptation stock before hammer modding for best ECM control over IQ. No criticism just genuinely interested as its the first time I've hear someone doing it in that order.
Giberish33 is offline   Reply With Quote
Old March 14th, 2018, 15:12   #9
TDITim83
TDITim83's Avatar
Default Hammer Mod accomplished....not much change
I have completed the Hammer mod.....I'm now at 3.2 IQ. I do seem to have a little more power, though still low powered for sure. Im gonna switch injectors from my 98 TDI Jetta.....see what happens
96 B4V Storm Grey 266K, 98 Jetta 258k
Old March 17th, 2018, 11:07   #10
greenskeeper
Fuel Economy: 53mpg
exactly what you said...each car is different. I also ran full timing advance (5 degrees) and no EGR.
Adapting the IQ first then hammering to 1.0 gave me the best fuel economy/power balance (provided I kept my foot out of it, as it did smoke pretty good when WOT with that setting)
Injection Quantity (IQ) Nozzle Size - Quantity Adjuster (QA) relationship mnorton TDI Power Enhancements 34 May 1st, 2018 08:30
Diesel injection pump Injection quantity itsrojass VW MKIV-A4 TDIs (VE and PD) 6 January 5th, 2016 23:28
Oil volume (quantity) changing after geared BSM installation? tiri.liri VW B5 Passat TDIs 16 September 17th, 2011 18:06
Rough Idle due to injection quantity issue? k_harley TDI 101 4 November 13th, 2008 19:49
Changing Injector quantity for Idle Quality? k_harley TDI 101 2 February 5th, 2008 07:00
Page generated in 0.16514 seconds with 10 queries
[Output: 97.00 Kb. compressed to 82.62 Kb. by saving 14.38 Kb. (14.83%)]
